Rough idle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KILLERK5, Feb 15, 2003.
  1. KILLERK5
    KILLERK5 1/2 ton status
    Oct 19, 2000
    108
    Aurora, Colorado
    I started my truck one morning last week when the temperature was below zero. It had trouble running and it kept dying. I thought it was just from the cold weather, but it hasn't stopped. If I don't give it gas it will die, but it will run after a couple of seconds. The exhaust smells like gas now as well. I don't know what the problem is. Please Help!!
    Thanks in advance!!
  2. tmaxxer9
    tmaxxer9 1/2 ton status
    Feb 12, 2003
    195
    Minnesota
    Ok as everyone here knows, I am no expert, but have you tried to raise the idle a little bit yet??
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    You got TBI right? Have you checked for codes? Could be a IAC or a Temperature sensor, those two things did that to me when it got down to teens in december.
  4. dyeager535
    26,980
    Believe you could also have an issue with the ECM temp sender circuit. If the ECM "thinks" the engine is warm, it will try and idle the engine like its warm.
    Scantool is a big help if you can justify it. Run about $150, if you start replacing parts blindly, you'll get there in a hurry.
    You can clean the IAC too, sometimes they get sticky apparently.
