rough idle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nc87k5, Oct 16, 2003.
  1. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    my 87 has the TBI and when I first crank it, the idle seems to be rough, it will idle high then low like it is going to cut off. I have already replaced the idle air control valve but that hasn't seemed to help. Any suggestions?
  2. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    the gasket between the tbi and the intake, very very common I must have done 2-3 in the 2 years i had my tbi van.
  3. jpaitala
    jpaitala Registered Member
    Sep 1, 2003
    33
    Imatra, Finland
    On my '89 TBI the problem was the MAP-sensor, after I replaced that the rough idle problem was solved. Cheap part, easy/fast to change.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Have you checked for trouble codes? You should always do that first before you start throwing parts at it.
  5. jpaitala
    Sep 1, 2003
    33
    Imatra, Finland
    Yes, definately check the codes first.
    I got no codes when I had that rough idle mystery and changing the MAP-sensor solved the problem.
