Rough / low idle with TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90BlazerK5, Oct 28, 2001.
  1. 90BlazerK5
    90BlazerK5 Registered Member
    Jun 27, 2001
    82
    Federal Way, Washington
    okay, the problem I'm having is a rough and very low idle in my rig. At first statup, the idle stays at about 1000, but after the engine heats up, the idle starts to fluctuate between around 600-800, and sometimes drops as low as 400..... Could this problem be caused by clogged injectors? I've got a 1990 350 with TBI. The Fuel filter was just changed, so I don't think this is the problem. Any help would be great!
    Where did all these damned dirty apes come from!?!
  2. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    I got a 1988 K5 350 TBI. Mine had the same problem. Thats because I went to MOGAS. I bought some Dry-Gas and went to Gulf and loaded the tank up with premium. Well it basically fixed it.
    35" All-Terrains... I don't get it.
  3. 90BlazerK5
    Jun 27, 2001
    82
    Allright, I'll give that a shot. All I know is that it's annoying as hell! Hopefully it works!
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Vacume leak?
    <font color=blue>Twiztid</font color=blue>
  5. mudmover
    mudmover Registered Member
    May 13, 2001
    20
    Southern California
    vaccuum leak poss. I would expect to see high idle all the time though. suspect vaccuum leaks from TBI base gasket (common problem) also make sure that your egr is not getting vaccuum at idle. sometimes the solenoids bleed vaccuum. any check engine light on? check your ignition system condition (plugs, cap rotor) is the problem only at idle? or do you feel any misfire under load etc. is the problem worse with heavier electrical loads (ie, a/c on, lights on, etc.)?
    What do you mean you cant run <font color=red>35's</font color=red> and an <font color=red>easy locker</font color=red> and <font color=red>3:08's</font color=red> in a <font color=red>10 bolt</font color=red>?[​IMG]
