rough ride with a 6 inch lift
Discussion in 'The Garage' started by MEGALADON, Feb 4, 2005.
  1. MEGALADON
    MEGALADON 1/2 ton status
    Feb 4, 2005
    214
    HOUSTON
    is it true I will get a rough ride if I add a 6 inch lift to my 82 pickup.
    or is it only when you add blocks. this truck will be a daily driver.
    thanks
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    first off what size tires do you want.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Depends on what brand of springs you buy. They all have a different flex rating. For example Rancho is alot stiffer then BDS.
  4. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    33/12 is that correct, or are they just called 33's.
    nothing real big, its a daily driver. thanks
  5. sweetk30
    Nov 1, 2004
    25,537
    536
    3" body will do it for you, or 4" suspension will do 35" all day with minor fender rub in corners.
  6. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    won't need 6" of lift with 33s.
  7. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    do you know what company products have a smooth ride
    on there lift's. Ranchero claims they have a smooth hwy ride.
    springs up front and blocks in the back.
  8. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    And i can still have a 10 or 12 inch rim?
  9. sweetk30
    Nov 1, 2004
    25,537
    536
    if you want smooth ride and do 4" kit go with just springs and ubolts with arm for frt. and do flip kit in rear. and there is a thread on this now in here with pics. will make it ride sweet and smoooth......
  10. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    BDS and Tough country deliver the best rides out of all the springs, that seems to be the censensus around here. The blocks will keep the stock ride in the back, which is probably best. I have never ridden on the two spring brands I just mentioned but I bet they will ride about the same as the stock springs, maybe just a tad stiffer.
    6" of lift on 33's will look good, don't worry about it. I ran 33's for a long time with a 6" kit and it looked great.
  11. sweetk30
    Nov 1, 2004
    25,537
    536
    33" on 10" wide best for you.
  12. sweetk30
    Nov 1, 2004
    25,537
    536
    if you buy a ck5 member ship you get discounts from are vendors in the vendor area. and thay sell all this stuff and more. the $25 dollers is recoped asap from the 1 or 2 order.
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Personally I went with 6" springs front, and ORD 4" Shackle flip rear + 3" springs. (I like the rear level or slightly higher).
    In my honest opinion, Tuff Country or BDS is the way too go.
  14. mr_blasto
    mr_blasto 1/2 ton status
    Nov 8, 2004
    495
    Irvine, CA
    You definitely do not want a 12 in wide wheel. 10 inch would be pretty good, but you could probably use an 8 inch if you had to.
  15. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The best riding springs are BDS and Tuff Country. That being said the best way to make your truck ride better is to get a better shackle angle. Do a search on shackle angle and you will find lots of info on it. A good spring with a good shackle angle will ride very nice.
    Harley
  16. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    youl be fine i had 35z with a reallly worn in 4in lift.
  17. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    exactly, a 33 on a ten inch wheel will look a little wide and short. IMHO:)
  18. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Also, the taller the lift spring is the stiffer it will ride. 6" springs will be stiffer then 4" springs. If you have a pickup a shackle flip might not be for you. They are not recommend it you tow anything of decent weight.
    Harley
  19. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    do you have a web for both these sites. :thumb:
  20. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    ORD for both the shackle flip, and Tuff Country springs. Don't know the URL for BDS, but I'm sure you can find it by doing a search on Google.
