rough ride
Discussion in 'The Garage' started by mr_beer, Oct 18, 2004.
  1. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    I have a 6 inch rough country lift kit on my 78. The name of the kit is right ROUGH. Has anyone here modified their lift to ride smoother? /forums/images/graemlins/thinking.gif /forums/images/graemlins/usaflag.gif
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    You could take leafs out, but that will drop the lift
    If the swaybar is connected ditch it
    If the shocks are totally too hard switch them
    Otherwise it's new springs for you Charly !
  3. mr_beer
    Sep 10, 2004
    325
    Mt. hermon LA
    sway bar is in the dumpster. Which leaf or leaves would you take out? /forums/images/graemlins/usaflag.gif
  4. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I know only OF the operation/idea of leaf removal, I won't try and guess at which is proper
    Someone who knows will post up soon, hang in there
  5. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    they call em rough country for a reason!
  6. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Well yes, we've established that
    Do you wish me to laugh?
  7. Storm Trooper
    Nov 24, 2000
    4,640
    Are you sure all the bushings are well lubed and free to move? Everyone blames the spings when it's the bushings that are froze to the bolts. $.02
  8. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Flatter springs + good shackle angle = nice ride. What do you use your rig for, is it a daily driver or a wheeler? Do you need 6" of lift or would 4" do? What size tires are you running? Are you up for some trimming? Give us some more info here...!
  9. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I am just curious, do your front springs have plastic pads between the leaves or not?
  10. mr_beer
    Sep 10, 2004
    325
    Mt. hermon LA
    The truck is used as a farm truck and mild offroading. Mostly swamps here louisana so flexing isn't a big issue. I have a set of 36 inch military wranglers on now. I may be able to get away with less lift. Is there anyway I could remove one leaf from the spring packs and keep it cheap? Oh yea I do have the plastic pads in. /forums/images/graemlins/usaflag.gif
  11. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I have the 4" rough lift. I removed the bottem two leaves on mine but that was too much. so now I just have the bottem one removed and it works fine for me. Just remove one of the bottem two and compare the lift lost vs the ride givin by eather leaf. BTW those tires probly arent helping much ether. /forums/images/graemlins/burb.gif
  12. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    sorry! you could try pulling thr second leaf from bottom. leave the overload that should help. if the spring sag it probly wont be for awhile,like not the 1st week rough country springs must have a higher rate cause stiff seems to but the popular description.
  13. mr_beer
    Sep 10, 2004
    325
    Mt. hermon LA
    I'll try taking out the bottom leaf. I'm goning to wait and do it when I put my 3/4 axles. I'm just trying to keep it in budget, my labor is cheaper than new springs. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/peace.gif
  14. mr_beer
    Sep 10, 2004
    325
    Mt. hermon LA
    that welding icon and the flag don't look good together I wish I could change it now SORRY /forums/images/graemlins/doah.gif
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You can . Click on edit and do whatever you wish within the rules /forums/images/graemlins/waytogo.gif
  16. mr_beer
    Sep 10, 2004
    325
    Mt. hermon LA
    THANKS I'm new here and still learning /forums/images/graemlins/grin.gif
