rough ride
Discussion in 'The Garage' started by aknight_sa, Dec 5, 2006.
  1. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    hi guys,
    what will doubling the shock absorbers add to my car? will it be able to take rougher rides like in the sand as it now shakes badly when if i keep a steady speed...
    and how much will independent suspenstion cost if i wanted to do that?
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Double shocks will stiffen your ride quite a lot but it's not altering what the spring can take as such.
    Why would you want independant suspension? Best improvement over what we have from factory is to go coil over. Very do-able but expensive if you're not doing the work yourself.
  3. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    You don't need fancy coilovers to go fast in the sand.... (but they're nice!)
    If you look at some of the desert racing websites, so can see examples of trucks with leafsprings that do very well. Typically, the springs are custom made (Deaver spring, Alcan, etc) and carefully matched to a set of shocks so that the whole system performs correctly.
