Rough Running Engine
Discussion in 'The Garage' started by Hermy13, Mar 31, 2006.
  1. Hermy13
    Hermy13 Registered Member
    Aug 27, 2005
    22
    Iowa
    Ok i have a rebuilt 350 in my 98 chevy 1/2 ton. it has aprox 1000 miles on
    The problem im seeming to have is at low rpm it is surging and sputtering. we have checked plugs wires cap rotor timing fuel system ect we are out of ideas so if any of you got some idea feel free to chime in. Thanks
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Is it tossing out any trouble codes?
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Did you set the timing correctly? If not, the computer will try to compensate for your adjustments.
  4. Hermy13
    Aug 27, 2005
    22
    Iowa
    There is no codes commign up. the timing was set right at 0 with the scanner how all data says to.
  5. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Does the surging/sputtering at low rpm happen after a cold start and when warmed up? In gear & under load as well as out of gear? At what approx rpm does it smooth out?
    Have you stuck a vacuum gauge on it, and if so, what is the gauge showing when it's surging/sputtering?
    I assume all the plugs all look normal? All cyls have normal compression?
  6. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Any chance your EGR valve is open at low rpm (when it shouldn't be)?
  7. Hermy13
    Aug 27, 2005
    22
    Iowa
    it is rough cold or warm it doesnt seem to matter. in gear sitting at a stop light seems to be the worst. No havnt hooked gauge to it will check it out.
