rough running TBI 350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by G-Force8, Dec 17, 2006.
  1. G-Force8
    G-Force8 1/2 ton status
    May 15, 2005
    476
    DFW, Texas
    Whuz up gang
    Trying to trouble shoot the shimmy in my 3-fitty
    My '91 Burbs' TBI 350 started running rough ( physically shaking ) at idle. It runs smooth under acceleration,but with noticable power loss ( of course it is stock and about to hit 200K mi ) and a slight hissing that I suspect may be the throttle body gasket. I put new plugs and wires in, and it improved some,but not enough. I just bought a new O2 censor thinking that might help,but haven't installed it yet. I'm thinking I could pull the plugs and check the gapping.
    what do you guys think
    any suggestions?
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It sure sounds like a vacuum leak to me. Have you taken the time to check all you vacuum lines and fittings?
  3. G-Force8
    May 15, 2005
    476
    DFW, Texas
    nope, have not looked at a single vaccuum line
    I will do that when I plug in the new O2 censor in a few days
    thanks for your .02$
  4. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    2X :D
  5. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    third that:D
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Ummm..... maby replace the TB gasket? That will cause a rough running /high idle. As said check/ replace your vaccum lines. Also might want to pull the IAC and clean it. They get carboned up and leak.... But...... The first thing you should do before anything, is check for trouble codes.
    A new fuel filter would not hurt either.
  7. G-Force8
    May 15, 2005
    476
    DFW, Texas
    Thanks for the replies guys.
    I went ahead and bought a new TB gasket for good measure. Though, it hasn't had any problem high-idling,just shaking at idle. I replaced the fuel filter last year when I put in a new fuel pump.
    Without fail, a new O2 censor, new TB gasket and probably new vaccuum lines will be replaced with an oil change this weekend.
    We'll see
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    How did you get on? I had a bad idle at start up for years. It would run on 7 for anything from 5 to 30 seconds then clear itself. If you drove off before it was up on 8 it would not clear at all. I used to replace the plugs and it would be better for a week or so then back to acting up.
    I tore that motor down last week as I've just blown my newly rebuilt motor:doah: and needed some parts, and found that I had a massive crack in the head allowing coolant to get into the cylinder when not running.
    Funny thing is I never had oil in the coolant and never had coolant frothing up my oil. Weird.
