Round black vaccuum thing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Suffergauge, Dec 16, 2002.
  1. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    I know this is supposed to be for my heater controls. When I got my k5, none of the controls were hooked up. I only have one vaccuum line that runs from the firewall to this vaccuum ball. I found two nipples to plug it into. So I am imagining that it needs a vaccuum source. Does this source come rom the manifold / carb? If that is the case then easy fix and I have defrost again. /forums/images/graemlins/thumb.gif
    Thanks,
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    plug it straight into manifold vacuume
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what happenes if your heater controls int he dash still wont switch form vent to floor to windshield, still ?
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    The round ball on the firewall that you speak of is just a vaccum resevoir/isolator. Keeps the vaccum system under the dash seperate from the engine vaccum except when it charges. If your controls will not change from vent to heat to defrost then you have a different problem. Unfortunately under the dash. There are vaccum actuators on the heater box that controls a door which directs the hot air up/defrost, down/heat etc. If this vaccum actuator is leaking it will not change the position of the door. Also the line to the actuator could simply be disconnected or leaking. Hope I helped.
  5. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    If air is coming out of the defroster, vents, and floor all at the same time ... no matter what the setting is on ... then it could be a vacuum line under the hood.
    There is a line that comes out on the passenger's side and goes to a T behing the carb/manifold. This hose was leaking on mine, and I had the same problem.
    Thomas.
  6. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    How can it charge without a vaccuum source? I only have one line going to the canister. Two plugins tells me there should be another line. Am I wrong?
  7. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    The black canister is there to provide vacuum when the manifold vacuum equalizes (like at high RPMs). That's why the previous poster referred to it as a vacuum reservoir.
    At idle, you should be able to switch from defroster, to vents, to floor even if the black canister wasn't hooked up at all.
    If you only have one vacuum line coming from the firewall, you could hook it straight to manifold vacuum, but it would loose some of it at high RPMs. You should run it to that ball thing, and then run another line from it to a port on the intake manifold.
    If you don't have any other vacuum lines under the hood, then there must be vacuum caps around on the manifold. Find one that'll fit a line from it to the reservoir, start the truck, take the cap off and feel for suction. If it has suction, then hook the line to it.
    Thomas.
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    One line (smaller one) goes through the firewall to the heater control, the other line (bigger one) goes to the intake manifold for the vacuum source.
  9. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    Since it hasn't been properly hooked up in who knows how long, the res. may be empty? I will hokk it up and see where my troubleshooting will go from there. Thanks for all the info guys. /forums/images/graemlins/thumb.gif
  10. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    Sweet it works like a champ! /forums/images/graemlins/pimp1.gif
  11. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Great /forums/images/graemlins/laugh.gif Glad you got it fixed up.
    FYI: In reality, the reservoir should be more than empty ... because it just stores vacuum /forums/images/graemlins/wink.gif LOL!
    The only way the reservoir can go bad is if it gets a hole/crack in it.
    Thomas.
