Rounded Bolt Head, How to Extract?
Discussion in 'The Garage' started by Bubba Ray Boudreaux, Dec 20, 2003.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    You've read the title and that's the lowdown.
    It's one of the bolts on the carrier bearing caps on a D44. Fawking thing rounded off when I was trying to pull the gears.
    Is the best way just take a size smaller socket, apply BFH to said socket and beat it onto the bolt?
  2. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Have you tried to drill it out with a smaller bit than the bolt hole and then use an ez out?
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Actually, I'd try the next smallest metric socket (smaller increment) for the best of choice. I ain't no rocket scientist, that's my wifes job. The only other thing I might add would be patience. Good luck to y'all.
    Allan
  4. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Me no havy e-z out.....................
    I may drill and apply cutoff disc to bolt head......... /forums/images/graemlins/thinking.gif
  5. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    You can get some for cheap at your local auto parts store. I have used all kinds of them. I like the square ones best. They seem to get the most bite on the remaining metal.
  6. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    heat it, then try the small socket
    If that don't do it a pipe wrench/monkey wrench works good if you can get to the head
  7. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    sears has extractors... reasonably priced....
    If your good enough to tig a bolt to it thats a solution as well (without overheating obviously)
  8. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Wow
    That's a pertty important bolt
    first up its a 6 point bolt head right ??
    1st use a Good name brand Snap on , craftsman 6 point Scocket not a 12 point p.o.s.
    2nd then like Allan said use the next smaller metric scocket
    then like you said tap it on there real good make sure its all the way on
    then if at all posible use a impact gun not a rachet
    finally good luck
    R
  9. A&P
    A&P Registered Member
    Dec 3, 2001
    88
    San Antonio, Texas
    If you want to try a cheap fix without buying the ez out, get a torx bit just a little bigger than the hole you're drilling, but it has to be the kind that goes on a ratchet, and tap it in with a hammer. Put on the ratchet and back it out. Just try to go as big as you can, cause they can break easily. It's gotten me out of a bind before. They're pretty cheap. Just use it as the last line of defense. Try the socket first.
  10. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    cheap 12 point socket of the next smaller size, standard or metric, hammer it on, if you cant get it hammered on, use a cut off wheel and lightly split ONE side of the socket, then hammer it on and take that sucker out.. ive used this for removing the round edge wheel locks...
  11. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    These work absolutely bitchin. They have saved my ass many times at work. you hammer them on and as you loosen the bolt or nut the socket tightens itself onto the bolt. I dont know if craftsman has anything similar.
  12. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  14. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    they work very, very well. my Snap On set saves my butt consistently on the corroded marine stuff i play with...
    wish they had them suckers 20 yrs ago.. a very worthwhile investment...
  15. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    weld a bolt onto the head of the stripped one
  16. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Try welding a elcheapo socket to it. The heat will help loosen it up too.
  17. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I've got this exact set...works great...money well spent...ya don't know how bad ya missed 'em until ya got 'em...
  18. i8yrsuv
    i8yrsuv 1/2 ton status
    Aug 31, 2003
    327
    Santa Rosa,NOR KAL-IFORNIIA
    I was always lucky to have a mig welder around ..I have used a piece of steel to weld to the stud or stripped bolt, then while it was still hot, turned it to loosen it ,the broke the the metal bar of the bolt . Some tines I drilled a hole in a piece flat bar so I could weld it to the bolt and not to the part that I was saving .
    If you are going to use extractors ,use only the square kind not the screw kind and with the square kind, tap it in just enought so they bite . DONT BREAK IT OFF IN THERE !!!! /forums/images/graemlins/deal.gif
  19. 72beater
    72beater 1/2 ton status
    Oct 11, 2002
    224
    Nation\'s Capital
    I have welded an old 1/2 inch extension on w/ mig and then cranked it off with a large 1/2 inch impact wrench. Works like a charm, just be careful not to weld the bolt to the carrier !
    Ernest
  20. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Good ole Vise Grips always work wonders /forums/images/graemlins/thumb.gif
