Routing my exhaust 2 into 1 then outside the frame rail - anyone else?
Discussion in 'The Garage' started by BorregoK5, May 27, 2003.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I just finished making a new 2 into 1 y-pipe for my manifolds so I can run a single 2 1/2" pipe outside the frame right between the front shackle and the tranny crossmember. Going to run a single muffler under the passenger side and route it out just before the rear tire. I was going to run a full thorley tri-y with their 2 into 1 system for big torque but blowing a muffler off yesterday caused me to step up and make changes right away. I'm only half done but already I have all the room I needed for a 4-link in the rear! /forums/images/graemlins/thumb.gif Anyone else running 2 into one with no cat, or outside the frame?
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    I experimented with a muffler and pipe outside of the frame a couple of years ago. It was a tight fit, loud as hell and I worried about it getting smashed off road.
    With the diesel I run a single and came outside the frame with it right near the bumpstop bracket in the rear. From there it follows the outside of the frame real close to the floor with the tail pipe aimed slightly down and out at a 45 degree angle.
    It's nowhere near the springs and even at full stuff there is still a ton of clearance around it. It also still exits behind my rear tire...
    Rene
  3. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    All routed / installed and what a difference. It went from a loud popping rumble to a mild toned growl and more bottom end than before ( y-pipe and scavenging effect). I'm using about half as much pedal around town as before and running a little cooler - guess I had a lack of backpressure with the true duals? You can definately tell its pushing more air through the single muffler and it has a bit less power at high rpm but thats ok, I use that a lot less than the lower rpms. Looking from the t-case to the axle between the frame rails and wow, what a wide open space... just a driveline now. Guess I should fill it up with links!
  4. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Where did you end up having the end of it dump out? Would love to see some pics when you get a chance.
  5. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Pic's would be great!
    /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I was going to do that at one time by switching to rams horns. But then I built the subframe and body, which made it pretty much impossible to keep the exhaust safe out there. So, I run a stock cross over and single 3" down the driver's side. Still trying to come up with something better...
  7. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I filmed a sound bite for my archives of the 2 into 1 exhaust note - its really small and short but has a still of the exhaust. I like the sound - but the 2 into 1 should have collected into 3" pipe through the muffler and out but I reused my old pipes to mock this up and see if I like it. I'll correct that when my flowmaster arrives- might run the quieter 70 series on it though. I'm fab'n up a plate to guard the area the pipe crosses under the frame. Its a rather easy area because its so close to the crossmember. This is an area that having a tube chassis would make easier - exhaust routing without interference.
    http://www.echobit.com/video/2into1exhaust.wmv
