rpm drops
Discussion in 'The Garage' started by aaf815, Jan 29, 2006.
  1. aaf815
    aaf815 Registered Member
    Jul 9, 2005
    30
    socal
    i have a proplem with the blazer when the blazer is in parked and its ideling it sound like its going to turn off. sound like the rpm drops and then it goes up and drops again. whats can it be?and the motor is a 350 tbi
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,853
    280
    Truckee, CA
    my first guess would be fuel pump, or clogged fuel filter.....
    but lets see what the more experienced guys here say.....
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    plugs and wires mabey.
  4. Bushido
    Bushido Registered Member
    Jan 25, 2006
    38
    Hawaii
    350 tbi
    First off definitely check the basics like said above.Is the "check eng lite" on?---I would check the throttle body for carbon buildup between the blades and bore.Clean with throttle body cleaner and clean rag or old toothbrush.Check throttle body base gasket,these are common for breaking causing a vacumn leak.This usually causes a high idle but since it's very easy to check...Possible I.A.C. valve but that would be difficult to check without the right tools.---EGR valve may be stuck open.
    If you can give more info. would be helpful.
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Is it throwing any codes? that would be very helpful, sounds kind of like the computer is confused and reverting to limp mode
  6. aaf815
    Jul 9, 2005
    30
    socal
    the check engine lite is not on. throttle body is clean.
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Surging on TBI I have always been told to check the TBI to Intake gasket. If it is pulling air under the gasket it will surge. Use carb cleaner and spray along the base of the TBI. If the idle smoothes out it is a bad gasket.
    Ooops did not see it was already posted.
    Ira
