RPM limiter for HEI?
Discussion in 'The Garage' started by garlicbreath, Apr 28, 2005.
  1. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Is there anyway to have an rpm limiter with an HEI distibutor?
  2. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Yes you can. MSD part #83645. $74.88 at Summit.
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Stock modules used to run out of oomph at about 4.5k-5k That not true anymore? If it still is true, there's your cheep option.
  4. dyeager535
    26,979
    They won't stop you from revving it higher.
    They might start having problems that high up, but at no load (usually why you want a rev limiter) you can easily exceed the supposed 4500RPM "limit".
  5. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Summit sells a variable control rev limiter... good for unlimited applications depending on the chip you put in... Summit part number ATM-5301 for AutoMeter, MSD-8670 for the MSD version...
  6. garlicbreath
    May 17, 2003
    1,136
    Denver
    I have the MSD billet HEI, if that helps.
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The previous owner of my truck swapped in a HEI and didn't do anything about the resistance wire. Stupid thing was only getting like 8V. The motor wouldn't rev at all...it was so bad that if you left it to the floor it would never shift out of 1st gear.
    I say the easiest way is to toss in a ballist resistor :grin:
