RPM question
Discussion in 'The Garage' started by grunt11b40x, Oct 2, 2003.
  1. grunt11b40x
    grunt11b40x 1/2 ton status
    Mar 1, 2003
    124
    winston salem, nc
    I have a 350 with a truck/rv toqure cam. just got the k5 on the road yesterday and noticed that she was pulling 4grand at 50mph. tires are 33's auto th350 tranny. is anyone out there pulling about the same RPM's at that speed? /forums/images/graemlins/truck.gif
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    What gears are you running?
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    4000RPM at 50MPH? geez I hope your running 4.56 or 4.88
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Are you sure that your tach isn't set for a 4 cyl or 6 cyl? Lots of tachs need to have a couple of wires cut to run them on an 8 cyl, if you don't cut them then they will read high. You would need to have 7.86 gears to actually turn 4000 RPM at 50MPH, unless your tranny is slipping in glorious fashion...
  5. grunt11b40x
    Mar 1, 2003
    124
    winston salem, nc
    I guess i need to check my tach then, i forgot about that. as far has gears go i am sad to said i don't have a clue it's a stock set up for a 75 k5 guess i need to get a litle dirty and find out /forums/images/graemlins/tongue.gif
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    does the truck sound like its turnin 4 grand? also, are u sure you dont have it in 2nd? my column display is off its between 2 and D on mine when im in D.
  7. dyeager535
    26,979
    Your speedometer is wrong anyways. If you've never changed the speedo gears, it can't be right with that size tire. Going to have to figure out your actual speed before saying the tach is wrong.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Even if it was off...4,000 RPM in 3rd gear would be very fast.
  9. dyeager535
    26,979
    So if you don't want to know the real answer, why bother with being accurate in the first place. /forums/images/graemlins/rolleyes.gif
  10. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Mine run's about 2800 at 60 mph. 33" tire's, 4:10 gear's, TH350. /forums/images/graemlins/eek.gif
  11. grunt11b40x
    Mar 1, 2003
    124
    winston salem, nc
    well It does not feel like she pulling four grand, while driving i switched the tach from 8cyl to 4 cyl thinking that it should change the reading on it and it only bumped down about 5oo rpm's I think the tach may be shot
