RPM SWEET SPOT
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 2BLAZERS, Nov 8, 2002.
  1. 2BLAZERS
    2BLAZERS 1/2 ton status Premium Member
    Oct 12, 2001
    513
    4
    KEIZER, OR
    Okay I have a 91 Blazer. I am gathering parts to do a 1-ton running gear, lift, and tires all at the same time. This is a daily driver to work (5miles), must be driveable on the freeway and everywhere else.It will be off-road in the Oregon/Washington area a couple times a month. What is the rpm sweet spot for the 350 engine? Yes I have Overdrive. I am trying to do it once, the right way. I have been leaning towards 37-39inch tires with 5.13 gears. Any help would be appreciated.
  2. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    That depends on a lot of things.
    Every motor is diffrent.
    Cam,heads,exhaust,weight of the vehicle affect the performance of the motor.
    I would look at one of the gear calculation charts.
    If you know where your motor likes to run just match that RPM
    with the tires and gear ratio from the chart.
  3. dyeager535
    26,978
    I would agree with the previous post. My truck really likes running in the 2250 range, and assuming a "stock" rebuild (it was purchased running about 15 years ago, looks stock, obviously not an aggressive cam) that range should probably suit you well.
