RPM w/ gears and35's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Sep 25, 2001.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    RPM w/ gears and35\'s
    I have no idea what my gears are and i have 35 in bfg mud T's... when im crusin 60 maybe 65 my spedo is prolly off w/ bigger tires. The tach reads like 2400 or so in 3rd gear wich is 1:1... is there a way to tell gears by rpm at a certain speed?
    6in 87' K5 w/ 35" BFG muds.
    Kn filter
    What I need: 4.11 gears, Lim Slip Dif, Force2 Catback, rear springs , Throtle body spacer.
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Re: RPM w/ gears and35\'s
    3.73's.....
    Marv
  3. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    jack the back of the truck up and turn your tire one full turn and count how many times the driveline makes a compleat turn say it makes 3 and 3/4 turns that would mean 3:73's 4 and 1/4= 4:11's and so on
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    I would say 3.43s too. I have 3.73s and with 36x12.50s on right now it cruises at about 1800 or so.
    Later
    Have you driven OVER a Ford lately?
  6. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    taking off its slow as [censored] and so is giving it gas in 3rd gear... it picks up really slow... So 4.11 gears would help alot ? Im thiking of getting a throtle body spacer , tru-duals, maybe a cam. That should allhelp with off the line power right.
    Kn filter
  7. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    I have 35's too, when im in od at like 60 on the speedo its at about 2000, is this 3.73or 4.10??
    <a target="_blank" href=http://www.bigredjimmy.iwarp.com>http://www.bigredjimmy.iwarp.com</a>
  8. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    It is hard to really tell, unless you pull the diff covers, or spin the tire and count etc. etc. etc. Using my formula comes out to 4.56. But that my not be what you have. There are alot of factors, most important is the true MPH. For example, if you did not change your speedo drive gear or have you speedometer recalibrated, you are probably actually doing 67.7 mph when your speedometer is reading 60 mph. And if this is the case, I would say that you more than likely have 4.11's. But if your true speed is in fact 60 mph, than you should have 4.56's. Better check just to make sure. Also, the advertised diameter of the tire my not be accurate. It could only measre out to 34" or less wich would also affect the caculation.
    Keep it simple
  9. wakedog
    Mar 7, 2001
    233
    Minnesota
    thanks for the help, im going to pull the cover and count them but i just wanted to get an estimate. thanks.
  10. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    sounds like a match to my 4.10's w/ 35" MT's... approx 2 g's
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  11. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I seriusoly doubt the spedo was recalibrated and it was going between 60 and 65 didnt really check... im tkaing it to a shop this weekend and asking them to open it up and ocunt ... if i need new gears ill get em and get a auburn posi in the rear.
    Kn filter
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
