rpm's n' gears
Discussion in 'The Garage' started by jones, May 22, 2004.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    rpm\'s n\' gears
    i'm assuming some of you run your rigs on the freeway.what rpm range are you running with what size tires and what gear ratio.ex.)a guy told me he was cruisin at 4k at 55mph,w/4.10's and 33's w/ a 3spd auto.is that typical?
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Re: rpm\'s n\' gears
    @ 60mph I'll hit around 2650RPM with a 1:1 non overdrive 3 speed automatic, maybe a little higher accounting for TC slippage, this is with 5.13 gears and 42" TSL's.
    This is with a Big Block Caddy motor that hates high RPM's
  3. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    4K is way to high to be running continuously. I am running 37's, with 4.56 gears, and a 700r4 overdrive transmission and at 65mph, I run about 2350 rpm's. Thats a pretty good rpm range to keep the engine and gas mileage happy.
    -Harrison
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I have 35's, 4.10's, th700, and a built 406 SBC. I cruise at about 1,700-1,800 RPM's. /forums/images/graemlins/whistling.gif
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm running 4.10's and 33's with a TH350(standard 3-spd auto) and I'm running no where near 4K, more like around 2600
  7. jones
    May 17, 2004
    379
    IONIA,MI USA
    so a 4.10 and 31-10.5'swill be just peachy,huh? /forums/images/graemlins/thumb.gif
  8. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    (MPH X Diff ratio X TCase Ratio X Trans Ratio X 336)÷ Tire Diameter = RPM
    Therefore:
    (55mph X 4.10 X 1 X 1 X 336)÷ 31 = 2444rpm
    Try 80mph
    (80 X 4.10 X 336) ÷ 31 = 3555RPM
    Tire size can make a huge difference
    Try 33"
    (80 X 4.10 X 336) ÷ 33 = 3339RPM
    Try overdrive and 31's
    (50MPH X 4.10 X .70 X 336) ÷ 31 = 1555RPM
    (80MPH X 4.10 X .70 X 336) ÷ 31 = 2488RPM
    This is assuming direct drive. Torque converter slippage will add a few more revs.
