RPM's?
Discussion in '1982-Present GM Diesel' started by 82K5_6.5L, Feb 11, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    RPM\'s?
    i dont have a tach on my blazer but would really like to know when a diesel redlines? i want to get one but that costs money, and money is low now..just curious
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Re: RPM\'s?
    It's governed to 3600 RPM which makes it awefully hard to over rev it. Having a SM465 I have found the governor once/forums/images/graemlins/eek.gif on a shift from 2nd to 3rd. It was like someone shut off the fuel...I guess I held it just a bit too long before shifting/forums/images/graemlins/blush.gif
    For tach's do a search on this forum. It's come up a few times in the last couple of months.
    Rene
  3. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Re: RPM\'s?
    Stewart-Warner makes a nice tach. 0-3500 RPM with a 3 5/8" diameter face. It is available thru carquest- $105-120, sender is about $30-35. Picks up it's signal from the flywheel teeth.
    And yes, 3600rpm.
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Re: RPM\'s?
    Do you have the part # avaliable?
  5. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    Re: RPM\'s?
    I'll post the part #s when we get everything ironed out.
    Finally got the instructions for the tach, weren't in the box, and it don't look like it'll work with the sender. I have SW's 800# and will try to get ahold of their tech line for the proper part#s. Might even turn out I have what I need, will keep you all posted.
  6. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    Re: RPM\'s?
    OK, have part numbers.
    Carquest#(Stewart-Warner#)
    Tachometer---CPS 80588(82636)
    Mag pickup---CPS 80816(990-K)
    I paid $116.96 for the tach and $30 for the pickup. Correction on the size, it is 3 3/8 dia, not 3 5/8. 0-3500 rpm.
  7. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Re: RPM\'s?
    So how does the pick up work? How do you install it? Do you need to pull the tranny?
  8. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    Re: RPM\'s?
    I'm gonna try and mount it to the aluminum inspection cover. It has a 3/4-16 external thread on the sensor, so you drill and tap a 3/4-16 hole and turn it in until it's close enough to the teeth. You could pull the trans if you wanted to mount it thru the trans case I guess.
