RPO Code?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, Aug 31, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Ive got a 1984 Blazer with the original rear and and axle ratio. My RPO code is G80 for Gov-lock and then GQ1 which is listed as "Standard Ratio" What is the ratio that GM is refering to as Standard ratio? I couldnt find anything listed on the axle tubes. I know I can jack it up, or take the cover off, but im just wondering what ratio GM uses as "standard ratio"
  2. dyeager535
    26,975
    http://www.slosh.com/cars/brochures/ the brochure for your year will tell you standard ratio, which was probably based on engine/tranny combo, and if it was a CA truck or not. I'd guess 3.08 or 2.73 though.
