RS5000 vs ES3000: Also a Shawn ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by laketex, Aug 31, 2000.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Ok guys, since I can't afford the 9012 right now, there's two options I've found.
    Rancho RS5012 is priced at approx $150 for 4, measure 33.10 open and 18.94 closed
    Procomp ES300 series priced approx $115 for 4, measure 33.83 open and 18.82 closed.
    My question to you is do you think the procomp shocks stack up to the ranchos? They are about 1" longer and 35 bucks cheaper. Which one is softer?
    Also shawn, your setup is close to the way mine will be. Even with the revolvers, do your shocks limit travel the way your 9012s are setup or do you think another .84 of an inch would help matters?
    Thanks.
    Bryan
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I ws told that the 5000's and the 3000's were made by the same company and I believe they are the same shock, other than the length differences you posted.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    The rear 9012 shocks (with 6" lift) in the stock locations will still limit travel (the extra amount you mentioned won't help). You need custom rear mounts and angle the shocks to avoid the shock limitation for both droop and full compression.
    The fronts may benefit a little as long as you use the F250 towers which I think you have.
    Shawn
    87 K5
    few mods
  4. laketex
    6,220
    North Texas
    Ok thanks guys. I plan to do a Depdog style rear mount on my truck, so I think I'll go with the 3000 series and see how that is. Only a battery and those shocks to go and we're running. (hopefully)
    Bryan
    [​IMG][​IMG]
    Durant, Ok
  5. laketex
    6,220
    North Texas
    BIGDADDY
    Bigdaddy, you mentioned you can get the procomps readily. You have a price better than $115/set? Let me know, I'll be ordering early next week.
    Bryan
    [​IMG][​IMG]
    Durant, Ok
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Re: BIGDADDY
    Pretty sure the Ranchos are made by Monroe, as are many if not most other off-road company branded shocks. I know a guy who used to work for Monroe, and he said that they manufacture shocks under a lot of different brand names, and they are one of the only US shock absorber manufacturers.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
