RTV Question
Discussion in 'The Garage' started by Hossbaby50, Mar 27, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I need to replace my water pump this weekend. What color RTV should I use on it? I have copper, blue, and black. I used black on my thermostat, and it leaked. So I went to copper and it has held sofar. Should I use the copper or is there a specific color I should use. thanks
    Harley
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    The water pump should come with two new gaskets - that's all I would use.
    If you do resort to RTV, I'd use the blue stuff.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Gaskets are usually better. I just install them after I clean the block up real nice at the mating surfaces.
    But I'll second blue or copper RTV.
    John /forums/images/graemlins/usaflag.gif
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    It does have the gaskets. If I don't have to run RTV, thats even better though. Then I don't have to wait for it to dry.
  5. heavy4x4
    Aug 28, 2002
    3,270
    Yeah, if you've got the gaskets, just clean up the two surfaces good (scrape off junk with scraper, maybe light sanding too) and then just use the gaskets by themselves. Only tricky part is getting the waterpump mounted without the gaskets falling through to the ground a couple times. /forums/images/graemlins/smirk.gif
  6. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    This is a serious question...you don't use RTV with gaskets? I just bought both...haven't done anything yet...but it would be nice to know for sure.
  7. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Use a short length of sewing string, or some real light fishing line. It will allow the bolt to go through but hold the gaskets on until you can get the bolt started. Then, as soon as its started, just break the string and you're good to go.
  8. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Use copper, but use a real thin bead. Smear the RTV on with your fingers. NEVER USE BLUE RTV
    Dan
  9. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    NEVER USE BLUE RTV
    Ok I'll bite, why? /forums/images/graemlins/confused.gif /forums/images/graemlins/smile.gif
    I usually use copper, but what's the difference?
    Thanks,
  10. heavy4x4
    Aug 28, 2002
    3,270
    Nope, I don't use RTV on the gaskets if I've got 'em. Some people do, but not me. That's what gaskets are for; if you had to smear each one up with RTV before installing it (on both sides) think of all the extra work and money a factory would need in putting and engine together. It just doesn't happen.
    (Go ahead "gasket experts" flame on /forums/images/graemlins/smirk.gif)
  11. heavy4x4
    Aug 28, 2002
    3,270
    Not a bad tip...I kinda like it. Thanks. /forums/images/graemlins/thumb.gif
  12. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    As far as RTV goes, all I ever use is the black stuff. I use it whenever I use RTV, like on diff covers. As far as using it with a gasket, I wouldn't. Use one or the other, just not both.
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  13. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Blue and clear RTV are a real slick compound. They allow oil and coolant to pass right by. The only time I have ever seen blue seal was on a front axle, and thats because gear oil is real thick when its not hot. Black, grey, or copper are the best to use when putting things together. I use copper on water pump gaskets, and on edges of valve cover gaskets(keeps them from slipping when istalling). I normally use black or grey for oil pan gaskets when they are multi poece gaskets. As for intakes, the grey works awsome to seal the front and back. Grey is intended to do things like that. Most newer chyslers and imprts dont use oil pan gaskets, and they recomend the grey silicone. Its the only one that doesnt leak.
    Dan
  14. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    The trick to getting stuff to not leak with RTV is you have to apply a real thin, even coat all the way around. It is best to do so around places with thin gaskets, like timing chain covers. The RTV will fill in any imperfections in the cover or the block. I always smear the RTV with my fingers to get an even coat. It is messy though.
    Dan
  15. BowtieGuy3
    BowtieGuy3 Guest
    The trick lies in that rattle can of red spratack, that [censored] hold gaskets in place like a charm.
    I would personally go with Fel-Pro w/p gaskets, but the replacement ones are ok too. I'd definately use the Blue gasket snot. Nothing else is quite as good for water related uses.
  16. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Silicones are all similar with the main difference being the temp range. Blue, black, red, then copper as far as temp resistance from lowest to highest ratings. I now use the copper on everything..... stay away from the generic stuff & buy Permatex brand. I have found this to be the best stuff going. Silicone is good for sealing thick gaps... Oil pan, valve covers, intake manifold rails etc. Most silicone is not good around gasoline. Silicone will also make gaskets slide out of place (I've seen waterpump gaskets blow out from using silicone on them) The best advice said above was to use "high tack" or gasket shellac on the water pump gaskets. Coat, install on block, let dry & install the pump without fear of them sliding out of place.
  17. bigbluek20
    bigbluek20 1/2 ton status
    Dec 18, 2001
    119
    Loveland, Colorado
    I gave up using RTV on gaskets (unless at mounting surfaces between gaskets like the intake... this is an "as instructed" application).
    My conclusion is that it makes the gaskets slip out of place easy (especially on the old 4 bolt SBC valve covers) and with any amount of uneven application it doesnt seal well (one area up leaves a loose area).
    All gaskets using RTV only for the joints and coating bolts threads (especially water pump bolts). Be careful about use on bolts in torque sensitive areas (especially newer intake gaskets)... it can mess up your reading.
    And to answer the question, I use black. Machinest scolded me on blue and, after using black, I'll never go back. Seems to have a longer shelf life and a better seal.
  18. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    the only time i usually don't use RTV is if the paper with the gasket says not to use it or if it says to use something else or on rubber gaskets. when i do use it i use black,and never had any problems. i used it on my water pump 2 years ago and it's still holding strong. /forums/images/graemlins/thumb.gif
  19. BowtieGuy3
    BowtieGuy3 Guest
    I will use RTV, or the gaskets...
    NEVER will I use both, that's just asking for a problem.
    If gaskets didn't work so well, engines would have been assembled with RTV to start.....
  20. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Thanks for the explanation. Now I feel like I need to go back and replace the blue stuff I've used in the past.
    I didn't buy the cheap blue stuff, the blue I bought was actually more expensive then the copper stuff. And its a light blue color, not the typical blue.. I dont know if it will hold or not, but I do know one thing, I will never use blue again.
    Thanks,
