Rubber brake hose acknowledgement
Discussion in 'The Garage' started by black'burb, Feb 17, 2006.
  1. black'burb
    black'burb 1/2 ton status
    Mar 11, 2005
    182
    Northeast WA
    I recently took the advice of someone on one of the threads here about using early 90's K3500 brake hoses on a 91 Sub 2500. They were an exact replace and are approx. 4-5 inches longer than stock and a whole lot cheaper than braided. Sorry I don't remember who you are but thanx alot. I wouldn't have completed half my projects without CK5 and all the knowledgeable people on here.:D
    napa #'s 38622(L) and 38623(R)
    91 v2500 350/4l80e/241 14bsf/10b 33's
    01 Cherokee DD stocker(for now)
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Ck5 is one of the best sources of info out there! I'll join you... thanks CK5!
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    The point of upgrading to SS braided lines is to reduce the expansion under pressure, and in this case to add length. So change for the brake performance, not so much just plain reach. Drive a vehicle with them and you'll see/feel the diff.:D
  4. black'burb
    Mar 11, 2005
    182
    Northeast WA
    understand about the performance of ss lines, but for lo budget replace of 15 y/o lines that won't see total hardcore wheelin was the point.
  5. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    So the newbs now know the trade-off:D
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    not nice
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    There is not that much of a difference, especially when comparing a new rubber hose in good shape. Sure, take a 15 year old rubber hose and I'm sure a new SS one is better. If SS was so much better than all of the manufacturers would be using them on new cars, but they are not.
    I've had both on my Blazer and there was no noticable difference, and my front extended Napa rubber brake hoses have been going strong for probably 5-6 years now.
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I tried
  9. GEORGIA GABE
    GEORGIA GABE 1/2 ton status
    May 25, 2005
    1,070
    Conyers, ga
    black burb, if you were reffering to
    http://coloradok5.com/forums/showthread.php?t=157096
    that was me and you are welcome.... I own and manage an auto repair shop, but when I need some suspension or off road related advise, here and pirate are the $h!t
    gabe:D
  10. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    I tried getting those NAPA (38622-L and 38623-R) brake lines for my Dana-60, and they did not work. I guess those are only good for 10-bolts and the Dana-44. I eventually had to get a custom set of hoses made, using my old fittings. It cost me $75.
  11. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    FYI - at least most 10-bolts and Dana 44's had different calipers from the factory......basically 10-bolts had a metric fitting where the brake line enters and D44's had a standard size. The standard GM D60's use the same lines as a standard 10-bolt, but these lines will not work with a D44.
  12. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
  13. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    The NAPA brake lines (38622-L and 38623-R) do not fit the caliper side of a Dana-60. They have some stabilizing ears, and a tack welded bracket, which a Dana-60 does not use. These ears and brackets interfere with using these NAPA brake lines on a Dana-60. The only company I have found so far that specifically specifies in their catalogs extended brake lines for a Dana-60 is SkyJacker. One-tons seem to be the "red headed step child" of many parts suppliers for Chevy Gen-2 trucks. I rarely find any company that specifically specifies 1-tons in their parts catalogs because 4x4 1/2-tons and 3/4-tons are more commonly modified than 1-tons; which is why there is less knowledge, mis-information, and mystery, when it comes to modifying 1-tons.
  14. black'burb
    Mar 11, 2005
    182
    Northeast WA
    Georgia Gabe, thanx again for that info. I do alot of searching thru the old threads and don't post much because most of my questions are answered with info thats already been covered. But when I do post, its not to be an a*#.
  15. GEORGIA GABE
    May 25, 2005
    1,070
    Conyers, ga
    black burb, That is exactly the reason that I posted those numbers, I had searched for them everywhere and found nothing. Im glad that some people got some use out of it.
    gabe
