rubber gaskets
Discussion in 'The Garage' started by nstarry, Dec 30, 2005.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    Hey I have a problem with my tranny to t-case seal leaking ! I have replaced it twice and it still leaks :mad: #?":>^%& my dad says use RTV on it ( the rubber seal ) Is this a good Idea? I have never used it on rubber gaskets before
    Thanks for any input
  2. dyeager535
    26,982
    191
    You mention rubber, are you talking about a gasket that seals the adapter to the transmission or t-case, or one of the metal clad lip seals used to keep fluids from swapping between the two?
  3. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    the gasket that seals the tranny to the t-case
  4. francis
    francis Registered Member
    Oct 11, 2005
    79
    kemp, texas
    man i work at a tranny shop and on every 4wd even if it has seals on the trans and transfer case i still put silicone. the seal kits don't even come with a gasket:doah: so yeah scrape off the gasket and put silicone on no gasket needed. just make sure that you have gotten all the old gasket off. also make sure you get silicone on the contact area the transfer case does'nt have much. good luck
  5. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    cool thanks man
  6. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    i have found that the rubber gaskets need 100% dry seal on both sides to seal best.
    and some newer valve cover gaskets cant have sealent on them. as thay are made to swell with oil on them to seal the best. rtv/silicone on them will make them no good.
  7. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    Thats what I was thinking thats why I asked ! but that isint working and that t-case isnt easy to pull and try again and again
  8. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Be careful, I have heard, not sure though, that rtv can be very bad for auto trannys.
  9. francis
    Oct 11, 2005
    79
    kemp, texas
    yes rtv can be bad for auto trannys. If you use alot, there will be a ton of rtv coming out inside and it can clog up the valve body and such so just don't over do it and you'll be fine!
