Rubber, Poly or...
Discussion in 'The Garage' started by BOWTIE, Jun 12, 2006.
  1. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    rubber, poly or solid mount for the motor tranny/xcases. what would be the best way to go with a 350, 400, 203-205 set up. just for reference my rig has the cage tied at 10 points and i was thinking on ditching the rubber or poly mounts and mounting everything solid to the frame. am i asking for trouble?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Solid seems like the way to go if you have zero frame flex.
    They do transfer alot of vibes from what fulltop told me about his.
    But in your case it might just be easier to swap in poly motor mounts.
  3. BOWTIE
    Dec 28, 2000
    2,018
    thanks..
    actually talking to fulltop is what got me thinking about the solid mounts. i'll post this on ak5 aswell.
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Me personally I think a little movement would be good so I choose poly. I know solid works because a lot of buggies go this way, but I think eventually something is gonna give, and i dont like the idea if an adaptor being the weak link.
  5. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    yeah, I'd be worried about the adapter and trans too... cast stuff tends to not like flexy frame action. IMO, if you decide to solid mount the engine/trans, then definitely do everything humanly possible to make the frame super rigid. Tie in the cage, box it... whatever ya have to do. On my truggy I'm gonna try going with all poly mounts.
    j
  6. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Going solid is asking for big trouble. Use poly, especially in places that dont require a lot of flex.
