rubbing on front of front fender?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Mar 10, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Last night I was goiung through a ditch and my tires rubbed real bad. Got out and checked where they usually rub - at the rear of the front fender - and it was fine. a few hours later I looked at the front of that fender and it was all dented in. Pulled it out a little with my hands, but it still looks like crap. This happen to anyone else?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have a 89 with no lift running 33s and except for cutting off a little of the rear front. I have had no rubbing anywhere.
    My rims have 3 1/2" of back spacing I think that is why I can get away without a lift. I have had the suspention wound pretty tight with no probs.
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I had that happen on mine. I ripped the bottom of the wheel well trim off and mashed the fender in some. I fixed it with a sawzall. /forums/images/icons/smile.gif
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Yeah I had that happen to me also. If you look at the link on my sig.,you'll see how I remedied that problem.
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Time to get some trimming...I also have some pics you can use for a refrence. Check the link below.
  6. dyeager535
    26,982
    191
    Tires are too wide, go with the 33x10.5's ; )
