Rubbing on the frame in the rear
Discussion in 'The Garage' started by lochenjons, Feb 13, 2007.
  1. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    My buddys k5 has a 4in lift with 35" super swampers. Not sure how wide but theyre WIDE. They rub on the frame in the back (barely), he wants to put a 3in BL on it :doah: to get more clearence. Should he get spacers for the rims? Would it be way to sketch to grind the smallest amount off the side of the frame where it rubs? I wanna convince him not to go with the BL, esepecially since he's keeping the tire size (front fenders are trimmed so that doesnt rub). And he thinks he wont have to worry aobut driveline, brakeline, etc with a BL. Driveline I understand but the brakelines are gonna be a problem and whatever else right? I say zero rates but he thinks they're too expensive, and know that I think of it, can you have blocks with zero rates?
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    What kind of backspacing on the wheels is he running?
  3. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    If its rubbing the frame then a bl wont help, because it just lifts the body not the frame. You never want to grind a patch of the frame out. Rear spacer will probly be the best. You just need to check them to make sure there not lose. What size backspacing is he running?
  4. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Haha yeah I never thought of that the BL wouldn't help :doah:. Figured about the frame, but its just barely its tempting. I dont know about the backspacing, but it's not like they're tucked into the fenders, they stick out way more than mine do...but I got 35x12.5
  5. Littlebubba44
    Littlebubba44 Registered Member
    Nov 1, 2006
    62
    western NY
    are the tires under deflated because that could be part of the problem?
  6. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    I'm not sure how that could be part of the problem but no they aren't
  7. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    find out what size tires he has 35x**.**R** and the back spacing on the rims
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I am just not seeing this. Even with an enormous amount of back spacing and 15" wide tires the tires should rub on the spring, or inner fenders before they come anywhere near the frame. I rub on the inner fender sometimes at full stuff, but thats not a real big deal. I included this pic for reference. I have 4" backspacing, and 12' wide tires on 10" wide wheels. I bet there is 8-9 inches between my inner sidewall and the frame plus the leaf spring and the shock is in that space as well.
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Same here I run a 37X12.5 on an 8" rim with 4.25" backspacing. I also run the inner with the inside sidewall of the tire but no where near the spring or Frame. The frame is set back under the body by about 7-8".
    Ira
  10. sandawgk5
    Oct 28, 2003
    6,881
    Here is another good reference pic.
    Ira
  11. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    my old k5 had no lift and stock rims with 32s and it rubed the inner fender/body but tht was it
  12. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Nevermind now that I actaully look at it it's jsut the wheel wells/inner fender its rubbing at.
