Rubbing sound from front wheel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bowtie4466, Sep 27, 2000.
  1. bowtie4466
    bowtie4466 Registered Member
    Apr 30, 2000
    13
    I have a roaring, rubbing sound coming from my front driver's side wheel. I have raised the wheel off the ground and spun it and it does not make the noise. It also will slow down or speed up with the wheel while driving. It does it more loudly when I am coming to a stop or turning left while slowing down. The noise will do it from the same place even if I rotate my tires. I put new brakes on about 2 months ago, and had new hubs, spindles and grease put in a year ago and 4wd works great. Any suggestions on where to start looking??
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    What about the ball joints? Jack the vehicle and grab the front tire at the top and bottom and see if it is loose.
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    See if your brakes are getting stuck/engaged against the rotor. If you look at the pads from both sides the one from the left should be more worn down. YOu might want to check the bearins and see if they have spun for some unknown reason. Just a thought, hope it helps.
  4. rich
    rich 1/2 ton status
    Apr 12, 2000
    279
    central NC
    Most likely wheel bearings. Were they torqued correctly (to factory specs) when they were greased 2 months ago? Was the locking "pin" still on the inner nut, so that it cannot back off?
    Richard
    '76 K-5 Blazer
    '90 K-5 Blazer
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Remove your caliper and try to shake the wheel. It sounds like bad bearings. Sometimes the caliper will give enuff resistance when you try to move the wheel that it won't budge.
    creepin' and crawlin'
    Jim
  6. 79Guy
    79Guy 1/2 ton status
    Jul 8, 2000
    178
    Southeastern VA
    Can a warn/frayed Speedo cable sound like a rubbing from the front wheels?
    '79 Guy
    1 Blazer - 7 Children
    http://79guy.coloradok5.com
  7. K5XLR8R
    K5XLR8R 1/2 ton status
    Aug 22, 2000
    210
    Washington State
    I have a similar prob when turning right at about 25-30 mph...but it only happens when going between these speeds...never any other time, it only started after i had new tires and wheels put on...?? i dont know...baffles the hell out of me...
  8. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I had something like this also it turned out to be the tape weights they used to balance my wheels. I'm running 15" rim and the weight was hiting the caliper as it went around. May want to look to see if this is it..
    C'moe
    <font color=black>the blazer is "Back in Black"
