rubbing?
Discussion in 'The Garage' started by 76blazerguy, Dec 16, 2004.
  1. 76blazerguy
    76blazerguy 1/2 ton status
    Nov 15, 2004
    125
    wichita, Kansas
    Hey guys, finally ready to buy my 6inch lift and im gonna be runnin 35's. THe problem is all this talk on here about peoples big ideas(10inch lifts etc) im scared that even my 35's will rub and tear my tires and fenders up? What you think?
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    im runnin 6in with 35's, stock wheel wells(well they were) and i never had any rubbing issues
  3. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I have 6" + 35's on my truck and for the most part I never have rubbing issues. My wheels are moderately wide (12") so occaisionally the tires touch if I hit a bump while turning, nothing bad though. Don't sweat it. :thumb:
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    You should be fine w/ 6" lift and 35's as long as you stick with a 10' wide wheel or less. You might have a little rub with a wider wheel. I ran 6" lift and 35's on 10" wheels and I had NO rubbing unless I was twisting it up pretty good.
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have 9" of lift with 35's and mine still bash the front fenders...
  6. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    At full flex while turning my 35's would rub with the 6" lift and when I stepped up to 8" of lift. With the 8 it wasn't really bad but withthe 6 I was just really careful as to the situations I would get into. It is doable just be situationally aware.....
  7. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    I had a 6" lift with 35 12.5s on 10" wheel and they never touched metal :grin:
  8. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    I think alot of it will depend if you leave the sway bar on or not also. if you leave it on, you'll flex less, but also less chance of bashing your fenders. Kind of of a question of what all you are expecting out of your truck:grin:
  9. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    im running 6 inches and 36x14.5's on 10 inch rims and rubbed bad when the wheels were straight with 3 inches cut behind the wheel. I re-cut the fenders tonight and took another 2 or so off... hopefully that will work.
