ruff idle
Discussion in 'The Garage' started by BlazerBuddy88, Jun 21, 2005.
  1. BlazerBuddy88
    BlazerBuddy88 Registered Member
    Apr 28, 2005
    17
    Schnecksville,pa
    :confused:
    hey out there this is my first post i`m a short time member and new time blazer owner. any ways i have a 88 blazer 350 TBI and it idles real ruff and stalls out when not giving it gas. also it hesitates when you give it gas. but once you get it past i`d say half throtle it runs like a champ. i just got the car today and i had a hard just getting it home. i already cleaned the the throtle body up with some cleaner but it still ildles low and ruff and stalls out. i ran out of sun light so i couldn`t pull the plugs but i have a feeling they might be bad. if any one might have some suggestions i am open to ideas. thank you. :)
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    fuel pump, my first guess, check your pressure, how many miles are on it?
    Reason i say that, i have the same setup, did the same thing a few years back, but slowly got worse to where it wouldn't even go into overdrive, it was running so bad.
  3. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    start with the fuel filter first then plugs, wires, cap and rotor and then the fuel pump just due to the price of parts... and trouble of dropping the tank, just my opinion.
  4. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Definately, that is the same route i took, basically ended up replacing EVERY sensor under the hood till i finally broke down and accepted it was something i didn't want to do. Wasn't really all that bad though, just alittle time consuming.
  5. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    id try this first and if this doesnt work.....
    then id do this
    might save you trouble
  6. dyeager535
    26,980
    I'd also check your fuel pressure instead of just assuming the pump is bad.
    Of course after you do a basic tune up, plugs and wires never hurt, cap/rotor I only replace if they have physical damage, there isn't anything to go wrong with them that you can't see, and aftermarket parts aren't the greatest quality anyways.
  7. BlazerBuddy88
    Apr 28, 2005
    17
    Schnecksville,pa
    :D thanx guys i`ll try that today and see how things go thanks again for the suggestions
  8. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    also...
    Check your EGR valve--if it sticks open even slightly it will cause stalling,poor idle,and hesitation during acceleration...along with all the other things already suggested.. :crazy:
  9. BlazerBuddy88
    Apr 28, 2005
    17
    Schnecksville,pa
    :D thanks for all your help guys every one was very nice and helpful but all it needed was a new set of spark plugs and now see purrs like a kitten. thanks again to every one
  10. 4xcrazy
    Oct 31, 2003
    9,472
    5
    AAAH, yes, must be nice to have it be something as simple as that,,,everytime i have had somethine go wrong, it's always been something major, :p: ,,guess i just got used to "assuming" a worst case problem, :crazy: ,,glad you got it fixed at a fairly cheap cost. :waytogo:
