ruger 10-22 cleaning
Discussion in 'The Lounge' started by surpip, Sep 1, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i did a google search, couldent find much
    i need a breakdown guide so i can take it all apart and clean it
    thanks
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Ain't took my SS one apart before, the blued one I had was really simple, I did put the safety in backards, just took it back apart and reassembled it correctly. Ain't much to it really! :wink1:
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    where do you start?
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    For fock sake:rolleyes: :D
    Here is some advice that I have heard for first time engine builders. Use baggies like zip locks and lable them and video or digi cam the break down.
    On a side note..........I went to a gun show once in Marysville CA and there was a guy who had two Ruger 10-22's mounted on a tri-pod with 100 round clips and the guy fabed up a cam hooked to a hand crank to work the triggers. As fast as you could crank the handle the twin guns would spit bullets. It was focking bad ass.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    thank you very much good sir
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yep just bought it from a pawn shop, appears to be close to new, probably under 50 rounds through it, stock is in good to excellent shape
    100 bucks:)
  8. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    My neighbor might have some insight,I could have him call you, but then again he has a rotary phone and is missing both index fingers...:D
  9. Corey 78K5
    13,055
    Humboldt County, CA
    Would You be speaking about Mr. Thumbs? :D
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Dio what I do with all my favorite guns.......... Take a bath with it.
  11. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    dale... I have a bunch of 10-22's... I have several I built using AMT receivers. They have a hole machined in the rear of the receiver so you can put a cleaning rod in thru the back (cleaning the gun correctly in the right direction).... I believe this mod is ok for the original 10-22 receiver IIRC,, ask some 10-22 experts...
    remind me and Ill shoot a pic of my best custom 10-22 for you
    isnt it nice to shoot 500 rounds for what a box of good 223 goes for... I like federal match ammo..
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i bought a snake, they are awsome, takes les than half the time to clean a rifle, or a pistol, and you can drop it throught the ejector port
  13. roadhawg
    roadhawg 1/2 ton status
    Aug 15, 2003
    495
    Oregon
    best semi auto 22 rifle ever made as far as im concerned.......good purchase! i also have a bull barrel mark 4 semi auto stainless pistol, ruger makes great guns.
  14. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    I bought a Mini-14 from a pawn shop about a year ago, and I downloaded a .pdf instruction manual from Ruger's website. I think they'll mail you one if you wanna go that route.
  15. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I worked back counter at a gun shop while in college & did a LOT of gun cleaning. As far as cleaning the 10/22's trigger group goes, what I found easiest was to use a Hoppe's saturated old tooth brush and work the Hoppe's down into the action & let it soak for bit. Maybe get that started first and let it soak while you work on the rest of the gun. Then blast it with Gun Scrubber and lube for use.
    Note two things about Gun Scrubber:
    A) It completely removes ANY oil, so be sure to oil blued parts against rust.
    B) It comes out of the can with some force and things like trigger groups are exceptionally good at re-directing that stuff into your eyes. :eek1: Eye protection is a MUST HAVE.
    Was very rare that I had to disassemble the trigger group to get it thoroughly clean.
    Hum.... 3 day weekend, excess ammo calling my name......:D
