Ruh Roh. Dead Truck
Discussion in '1992-Present Chevy & GMC models' started by willyswanter, Feb 5, 2003.
  1. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    A little background information:
    About 2 weeks ago I went out to start my truck and it cranked started and 2 seconds later sputtered and died. Then I cranked and cranked and cranked and about 2 minutes later it started.
    Now today, I went out and it did the same thing, started 2 seconds later it sputtered and died. But now no start. I checked for spark and thats all fine. But I can't hear my fuel pump. I checked the fuel pump relay and it's good and the wiring to the tank and it has power. So I'm assuming my pump died? If so whats the cost from the dealer on that? More than the 13.27 I have in my pocket? /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/blush.gif
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Try pouring a little gas into trot bod.If it runs till thats burned up it's prob. the fuel pump.Mines done that twice.You can listen under truck while someone turn ignition on also.Pump should run a little at first to build pressure. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  3. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yeah, forgot to mention mines a 96 and vortec so no open throttle body to dump fuel into /forums/images/graemlins/frown.gif. But my fuel pump is very loud and can be hurd from 10 or so feet away and I have nothing. The relay turns on for 2 seconds like it should be no pump. So I'm going to check the wiring to the pump and if it's got power I'm pulling the bed off I guess /forums/images/graemlins/frown.gif. Just filled it up last night with 34 gallons of gas and I'm not going to even try and lower that tank.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Its really not that bad when its full if you have a floor jack, except it might bend the sending unit if you put the jack under it...i dropped mine when it was full - 31 gals - by myself and i was really sick...the dealer wanted 70 for a TBI pump, got it at napa for about 40...vortec might be more thaough
  5. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Pump was 155 from the dealer. I figured this one lasted 155k miles must be pretty good /forums/images/graemlins/crazy.gif
  6. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    If your tank is in front of the axle, remove all of the bed to chassis bolts, and any ground straps, just leave the last bolt on each side in a couple of threads and stick a floor jack with a 2x4 standing upright and jack it up at the front crossmember. Kind of like if it had a dump bed on it. This way you won't have to totally remove the bed. Thats what I do with dodges and fords, but I don't know where your tank is so just a suggestion. Make sure you don't have any heavy items in the bed if you do this though. Good luck. /forums/images/graemlins/burb.gif
  7. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Too late but thanks for the info. Did it all yesterday in about 3 hours total. Just dropped the tank on a couple floor jacks and switched pumps and put it back up. Runs great now /forums/images/graemlins/thumb.gif
  8. ZonkRat
    Jan 16, 2003
    1,003
    Hope it lasts as good as mine has,over 450.000 miles and only needed one pump so far. /forums/images/graemlins/thumb.gif
  9. Rigger
    Rigger Newbie
    Oct 10, 2001
    NM
    I know by now you changed your pump out and all is well, but just had to add a comment about filters. My 5.7 Vortec's in-line fuel filter starts plugging off after about 6 mos. (20K mi.) and the pump in the tank starts getting noticeably louder (working harder) when it's about time for a new filter. I have switched to a NAPA gold now and will see if this makes any difference.
    Filters, when in doubt, change it out!
    Regards, Rigger.
  10. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yep, I change it every 4-5 months usually. When I only get 6mpg to start with I wanna try and squeeze every bit out of it I can /forums/images/graemlins/grin.gif
