Rumbling at decelleration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by eshorvath, Oct 17, 2002.
  1. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    I am hearing a rumble from the exhaust when I let my foot off the peddle..
    What causes this?
  2. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    Does anyone know what causes this? How can I fix it? Is it normal?
    Ed
  3. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    Ed
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    My truck does the same thing. I'm pretty sure it has something to do with a change in the exhaust backpressure when you let off the gas........
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    What gearing and tire size do you have? If its at higher speeds and you have low gears its engine braking and everything does that
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Ya oughta hear mine LOL
  7. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    did you just install a lift on it?...if so may be that the drive line angles are off...or maybe you even have a u-joint goin out..
  8. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    I am running 36x12.5 tires. I think I have standard gearing, I never changed it.
  9. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    I have had the lift on it for over a year. I just put a new motor in it.
  10. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    What would drive line angles or a u-joint going out have to do with rumbling from the exhaust?
  11. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    Would extending my ekhaust out further from the mufflers help? Right now my exhaust ends behind the mufflers. Goes from headers through 36 inch segments to mufflers.
    Has this same thing happened to you?
  12. Chaz88K5
    2,979
    Stockton/Lodi CA
    how about your catalitac converter?
  13. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    What Cat converter???
    Mine entire EGR, smog stuff fell off when I hit a speed bump. Heehee
  14. Chaz88K5
    2,979
    Stockton/Lodi CA
    hum...uh....yea....i dont have a clue...next
  15. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    definitely, if you extend pipe after the muffler, you will reduce the rumble.
    The longer you go the smoother the sound. Stock there was 3 feet after the muffler.
  16. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    Is it bad to run my truck like this?
    Ed /forums/images/graemlins/confused.gif
  17. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Just more noise, if you don't mind it
  18. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    Is it normal or ok for my truck to run like that? It only happens when I take the gas off.
  19. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    i know that if you have a transmission with a lockup convertor, it will continue to stay locked up until you either apply the brake or get on the gas again. my truck does it, but it's very quiet.
  20. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    my first thought was that its mildly backfiring. There are a lot of things that could cause it, on mine the valve which works in conjunction the smog pump was toasted (diffuser or diverter or something) so air when getting injected when it shouldn't. Do you have even a slight miss at idle? Is it worse when you are coasting at high RPM? Make sure your ignition is in good shape and timing is correct.
