Rumbling Noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by frank8808, Jun 3, 2003.
  1. frank8808
    frank8808 Registered Member
    Jul 20, 2002
    15
    San Diego CA, USA
    I have a 91 Blazer with 33's 2 1/2" lift and a cat back exhaust. When I'm driving and thing are warmed up I get a rumbling noise from the drive train. Mostly when I decelerate the gas and going down hill. /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif I check the rear end everything looks fine also checked u-joint on play.I'm stumped.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    rumbling noise? sound like air? or more like a vibration?
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I have the same problem. I found my driveshaft slip-yoke wore through some of the plastic /forums/images/graemlins/angryfire.gif splines.
    I tried changing the U-joints with no help.
    When I took the slip yoke apart, I greased it heavely and the vibe went away for ~50 miles.
    Good luck.
  4. frank8808
    Jul 20, 2002
    15
    San Diego CA, USA
    Well your not going to beleive it. I took it into trans shop.They said it's not the drive line or the u joints
    and he said the trans was fine. I't might be the diff. So
    I took it to 4 wheel parts where I bought the gears. They fixed the problem. It was one bad u joint. /forums/images/graemlins/cool.gif
