run on??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Nov 18, 2001.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Hello again here is my problem when I turn the engine stock 350 off sometimes it will studder as it shuts off or idle on. So to stop that I have been turning off the ignition off in gear ??????????? any thoughts.I have new plugs,cap,rotor,wires,new accellerater pump,fuel filter,all the standard tune-up stuff.
  2. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    I believe that if your timing is too far advanced it can cause your engine to diesel or run-on after it's shut off. Might be worth it to recheck your timing........
    <font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Its either timing or its idle. If you idle is to high it will do this also. I have that problem in my firebird. I have the idle so its 1000 in gear and 1200 in park so it will idle. If I shut it off in park it runs on if I shut it off in gear it is fine. Lower your idle 100 rpms and see if it goes away.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    thanks juat had to take back my new tach so I will put it back in tommorow -thanks
  5. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Also, if you engine is running rich it will build up carbon depositis in the combustion chambers. Those carbon deposits act kind of like glow plugs in a diesel. They stay hot enough to ignite the fuel even after the ignition has shut off thus the engine trys to keep running. That opens up a whole cam of worms including timeing, maybe some bad plugs, carberator, etc.
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  6. dyeager535
    26,982
    191
    If this is your 73, it won't apply, but my '83 with AC (assuming it was for AC, could care less, ditched it) had a kickup(?) solenoid for the AC on it, and it started to fail, so that when I shut the truck off, it forced the throttle open more, and it kept running. Unplugging the solenoid fixed the problem.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
