Run without a front driveshaft on a fulltime 4x4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigjblazer, Sep 30, 2002.
  1. bigjblazer
    bigjblazer Registered Member
    Apr 9, 2002
    89
    Atlanta, GA
    I have a 75 k-10 with the 203, and fulltime. Im about to do a 7" spring lift. Can I run without the front driveshaft (just for a few weeks till i can afford to get the shaft lengthened) or will this cause problems. Thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    im doing the same on my 79, i think it wil be fine in any range, i dont see why it would cause any problem. what overall length do you need ? I know of a couple shafts for sale, one is just under 30" long overall when fully collapsed which is too long for my stock height 203 truck by about 2"
  3. 78K5395MT
    78K5395MT Registered Member
    Aug 31, 2002
    27
    Winston-Salem, NC
    no problem, just like unlocking your hubs. you should definitely be fine for a few weeks. just make sure you re-lube your diff when you replace the shaft.
  4. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    You will need to put the case into the Lock Position. Otherwise, you will not move. Differential in the t-case sees the missing shaft as lack of traction, and will take the path of least resistance. (No power to rear) /forums/images/icons/crazy.gif
  5. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    Having fun w/ the '75? I had to lift my Blazer to compensate for the "Empty Nest"! LOL
    You do have to LOC the transfer case to get it too move w/o the front shaft. Do not go too long or you could damage the case.
    Good luck!
    Doc
  6. bigjblazer
    Apr 9, 2002
    89
    Atlanta, GA
    I sure am Doc. About to do the suspension lift, and a 3" body. and run those 38's. I took off the front bumper and cut out the front fenders, and took off the tailgate. Also sprayed the bed black. Put a dual stabilizer on it, and Im gettin a frame brace welded on next week. Ill have some pics for ya in a couple a days. Cut the mufflers off too. Its pretty loud, but thats how I like it. Kind of an excuse to not put a stereo in it. Got stainless steel brakelines, and a steering arm on too. Shes runnin great after I got a tune up. Thanks a bunch man. Ive had so much fun workin on this truck so far, and it's worked great.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I drove mine almost 2 months without a front drive shaft. Well, it sat in the driveway mostly, but did get driven occationally. Had an unexpected bill of moving a trailer house, and the Blazer had too wait. /forums/images/icons/frown.gif
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    oops thats right., yeah wont go anywhere when isnt in one of the two loc ranges, i dont knwo what i was thinking, :S
    good luck
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    i know a guy who has ran his for over a year w/out a front driveshaft. I didn't do any damage. When we pulled his tranny to replace it, we pulled the t-case and took it to get checked out. The guy opened her up, took a look, and replaced some seals. He said bolt it back in, it doesn't need a thing! You should be alright running it temporarily. I ran mine for 2 months w/out a driveshaft. It's a DD too. I had no problems. Just remember to lock it in! /forums/images/icons/wink.gif
  10. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    If you have a part time kit installed, you won't need to worry about it cause the diff. parts are gone from the transfer case and it will turn the back drivetrain without the front connected. I have a 75 and found a kit in the NP203 to my surprise.
  11. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I will add one thing to all the posts, I did that for a year, the T-case had no problem.
    But when I put Manual hubs on the front, and put back the front driveshaft, in a few weeks I ruined my hubs.
    IceMan
