Runnin a bit warm
Discussion in 'The Garage' started by mudbog42, Dec 3, 2006.
  1. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    Well I just recently installed an edelbrock performer intake manifold and carb spacer:D and the problem is since the install, my truck runs a bit warmer at highway speeds now:( , not to the point where it overheats, but to the point where it is irritating.:mad:
    What could be causing it to be running warm like that, city driving and low speeds, the temp is fine but as soon as I get on the highway the temperature rises a good bit and it didn't do it before:dunno:
    Not sure if this could be a possibility or if it matters any but when I refilled the radiator I used nothing but the 50/50 mix which I'm pretty sure should be fine but???:dunno: :dunno:
  2. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    try going to a 60 / 40
  3. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    what temperature does it run on the highway?
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Did you possibly put a hotter or more restrictive thermastat in it?
  5. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    If it does fine at slow speeds chances are it is not your coolant. Check for vacuum leaks. If you are running overly lean at cruise it can heat up the engine.
  6. mudbog42
    Jul 16, 2006
    452
    Florida for now
    It runs sometimes at exactly 210 or a a bit over that line. Used to run halfway in between the 210 mark and the mark before
    Used the same thermostat from the old manifold
    Will check again for vacuum leaks
  7. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Running lean. Better flowing manifold.
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    is 210 really too high? seems like that would help fuel economy. then again, i run a diesel and 210 is real good for me. :)
  9. mudbog42
    Jul 16, 2006
    452
    Florida for now
    Well checked the vacuum lines again and all good, and hooked the scanner up and its not reading lean, but before I started the motor I noticed coolant on the manifold and it seems to be coming from the thermostat housing, so I'm thinking I may have found my culprit, though it seems to stop leaking when the motor warms up
    So I guess I'll redo the gasket and see what happens
  10. destinbeachman
    destinbeachman 1/2 ton status
    Aug 31, 2005
    365
    Florida
    Have you tried tapping on it with a ball-peen hammer yet?:D
  11. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Do yourself a favor and go ahead and replace the thermostat... it's like a $4 part with gasket and will totally eliminate it as a problem.
  12. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Were manifold and spacer the only things you changed?
    Otherwise and in general, RedLine water wetter is great stuff.:D
  13. Slapperbar
    Nov 29, 2005
    2,747
    3
    Also the Specter housings are crap. Period. Get a stock one. The Specter housings have a really friendly sealing surface. Wavy.
  14. mudbog42
    Jul 16, 2006
    452
    Florida for now
    Yeah manifold and spacer were the only things changed and I have one of the stock cast iron housings
