running 307
Discussion in 'General Parts for Sale' started by cochino12, Nov 11, 2004.
  1. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    chevy 307, supposed to have been rebuild but I am not sure. GM aluminum intake, and heads from early 80's 350 (I can get casting numbers if needed). How about $100 or best. Thanks
    trade for good pass. fender 73-80
    inner fenders same years
    k5 rear glass
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I'd be interested in this motor. I'll be in denver next weekend and might even be able to come up with some good 73-80 inner/outer fenders to trade you. Just need to check on a truck I know about for parts /forums/images/graemlins/thumb.gif
  3. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Sounds good /forums/images/graemlins/thumb.gif
  4. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Have a good tailgatge?
  5. kennyw
    Jun 9, 2002
    13,223
    94
    I dont have any Blazer specific parts. The fenders I have now are rust free, but some minor dents that are very fixable. Good rust free inner fenders with them and even a core support if you would like it. I think the pass side fender was in pretty good shape and the drivers side was the one with the big dent, but I need to double check them. Havent had a chance yet trying to get ready for the trip to Denver. Though right now it looks like I'm going to need to post pone the trip 1-2 weeks due to my clutch not working when I got the new motor going for the first time tonight...
  6. cochino12
    Dec 23, 2003
    563
    Parker, Co
  7. J.R.
    J.R. Guest
    dont be to fast to give this motor away for cheap bucks. if its an early 70's 307 block, some of them can be bored out .100 over . lots of dirt track racers like these old blocks to use. just a little fyi.. good luck
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    boring a 307 1.125" just turns it into a 4" bore block
    thats a 302, 327, and 350 bore/block
    spend the $ on a 350 or 400 block, unless you want to spend the extra $ and still have a 2 bolt block- which probably doesnt matter in your case
    youd be safer with a 4" bore block rather than boring out a 3.875 bore block
    if you decide on boring it out then have the cylinder walls checked to make sure thers enough iron in the walls, just because its a 68-73 block doesnt mean its got thick enough jacket walls around the cylinders
    but why when you could just go pick up a 69-79 years 3970010 or 3970014 4 bolt 010 020 high nickle and tin block for cheap, they are common as hell
    http://www.clubhotrod.com/t9845-15-2.html
    good luck
