Running 4.56s, with 35"ers, and a 700r4 ** What about 37s?
Discussion in 'The Garage' started by NEK5, Dec 30, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Whose doing it???
    If you are, and like it, tell me why. If you are, and don`t like it, tell me why. If you`re not, and want to, tell me why. If you aren`t, and would never do such a thing, tell me why. :deal: :wink1:
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    im not, i dont want to, but i would if i had a rig with a 700...
    3.06:1 1st in the trans
    2.1 or something low in the tcase
    4.56 in the axle..
    29:1 gear ratio? sounds good to me!
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    In 4th gear, cruising the highway at 65, 4.56's and 35's will be nearly identical to having 3.73's with stock 29 inch tires. 1966 RPM with 3.73's and the stock tires, 1991 RPM with 4.56's and 35's. :cool1:
  4. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I wish I had 4.56's. I just put on 35"s with my 3.73 and now can barely get into OD on the highway. Especially with the heavy burb, I think 4.56 will be perfect.
  5. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    this is what I wanted to hear guys...keep it coming!
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    That's what's in my crew cab, perfect match. :thumb:
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I ran that exact setup for years. it's perfect. good low end power and still low rpm's on the highway.
  8. Mr.Jimmy
    Mr.Jimmy Registered Member
    Nov 20, 2006
    66
    Albuquerque, NM
    i have 4.10 in my jimbo. wish i had 4.88's though, my 35" tires are nice, but im goin with 38" tires, so 4.56 i think wont be enuff. on hills, my truck slows down pretty bad.
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i used to run 3.73s and 35s and i thought that was decent. 4.56 would be really good. i was originally planning on 5.13s and 36's since u got overdrive with 700r4, but ended up going bigger. id almost suggest 4.88s simply cuz u got overdrive
  10. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Very good combo. OD will allow a very low axle gear.
  11. HoodRich
    HoodRich 1/2 ton status
    Jul 30, 2006
    160
    Kernersville, NC
    Interesting, I'm finishing my rig up now with a similar combo, 4:56 700r4 40's and 208 until I can get my doubler built then out goes the 208. Only I wont be running mine on the highway.
  12. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    I have a set of Yukon 4.56s for a 14sf w/ install kit I am willing to part with....
  13. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    I've been running 4.56's with 35s and a 700r4 for 8 months now and love it, power off the line, good gas mileage if your easy on it because of low rpm's around town, and doesn't kill you on the highway, I can cruise at about 2200 rpms all day. i debated wheter going 4.10's or 4.56's and 4.56's was the right choice.
  14. k2mslskier
    k2mslskier 1/2 ton status
    Feb 18, 2005
    1,524
    Tucson, AZ
    x2. Does great in my 86 with a 4" lift.
  15. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    works great. i loved it. ran 4.56 and 33's for 2 years. overdrive gives you a nice crusing rpm. dont expect to cruise at 85 all day long though. i run 5.13 and 37's now, it's pretty close to the same tire/gear ratio.
  16. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    i ran that exact set up for a while... very good set up!
  17. Tominator II
    Tominator II 1/2 ton status
    Nov 5, 2005
    280
    South Park CO 80440
    Go 36s. I went through 1 set of Hummer military 36 inchers, one set of SuperSwamper tsl 36s in my 77 Jimmy with 350/465/205/4.56. Perfect match. My latest set of tires are 38.5 groundhawgs and I could definitely stand to switch to 5.13 gears.
  18. 88$PIT
    88$PIT Registered Member
    Sep 12, 2006
    66
    Lincoln CA
    That is the way I'm going. Best utilization of gearing for wide range of use IMHO.
  19. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Heres another one for ya!
    33s, 700, with 4.10s? Hows that????
  20. Tominator II
    Nov 5, 2005
    280
    South Park CO 80440
    3.92s or 4.10s would work great with 33s. especially with a 208.
