Running 4" TCI Springs (?RS 9012?)
Discussion in 'The Garage' started by DaveCowley, Jan 8, 2003.
  1. DaveCowley
    DaveCowley 1/2 ton status
    Feb 18, 2002
    196
    Provo, UT, USA
    Running 4\" TCI Springs (?RS 9012?)
    If I put F250 towers and 9012s on my front end will I need to get a longer travel driveline. Right now I have about 1.5" of spline engagement give or take on full droop. I just need to know any of you who are running this setup with the stock travel in the slip joint on the front DL.
    Dave Cowley
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Re: Running 4\" TCI Springs (?RS 9012?)
    I did have that combo on my K5, but it also had a D60 front (longer pinion snout). No problem with the spline engagement on mine, but might be on a stock D44/10B front when you flex.
  3. DaveCowley
    Feb 18, 2002
    196
    Provo, UT, USA
    Mine is a D60 also so it sounds like it should be fine. Thanks for the post. Anybody elses commentary is welcome.
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Mine was fine with the stock shaft, 4" lift, and 9012's. Also it's on a D60.
