running a t-case upside down
Discussion in 'The Garage' started by DesertDueler, Sep 6, 2004.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Can I run a ford 205 upside down. I have a divorsed ford 205, and am thinking about making a homemade doubler. It would have to make 4-5 hour trips. Any help is greatly apriciated.
    Dan
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How are you going to keep fluid from running out of the vent?
    How will you shift it?
  3. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Plug the vent, and make a new one on the new top. I am sure I can figure out the shifting. I can always make a shifter.
    Dan
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    How does the case lubricate? Are there any bearings that will get dry?
  5. semper-k-five
    semper-k-five 1/2 ton status
    Aug 16, 2004
    326
    Tulsa, OK
    i have a buddy that did the same thing to his samurai and put steel plate front to rear...i'll see if i can get in touch with him to find out what he had to do...
  6. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I believe a 205 just uses gears to move the oil, but I could be wrong. That is what I am worried about. I dont want a bearing to go out when I am on a long trip.
    Dan
  7. Blue85
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Is the goal to switch between passenger-side and driver-side drop? Finding a different 205 could be easier than rigging up a shift linkage for this.
  8. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    The goal was to switch to passenger side droop. But I guess I could use a ford axle, and fix the problem. The only bad part is the only ford axle I can get for free is coil sprung, but it is complete with torsion bars, track bar, etc. I guess I will be doing some fab.
    Dan
