running an auto at extreme angles?
Discussion in 'The Garage' started by sled_dog, Jan 19, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Been heavily thinking my 383 will end up with propane so now I'm wondering if the trans will be able to run the angles the propane would? This is a 700R4. What kind of angles can an auto trans get up to?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    30 some odd thousand off my own miles , hundreds offroad at all kinds of angles , no problems . I run a cooler now but didn't for 3 years of use . Some of the hills here are steep enough so you see sky before you reach the crest :k5: :k5:
    And then w ehave nearly everyone here running autos in the built truggys , they get real tippy and have way more power and they seem to hold up .........except Russ's :)
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    They can handle some pretty decent side angles. TheRobzilla gets almost to 90* before he looses tranny prime and the truck stops. His is a Th350.
    Harley
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Stock, a Th350 will loose prime anywhere beyond what would be considered "moderate angles". In fact, it will be able to handle driver's side up less than passenger's side up by a few degrees due to offset pick-up.
    However, with a "+3" pan and offset pick-up, I can go nearly onto the side before "loosing prime". This is basically the same thing Rob and most of the rock guys do to get more angle.
    I also run about 1 qt over full. Any more than that and it blows it out.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    that helps I was planning on a deeper pan anyway.
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I run a 700r4 and my buddy has a C6 and neither of us have had problems. In fact, I have a picture hanging up on my desk at work with my K5 climbing a very steep hill when I got crossed up in a rut so the driver's side front was about 2 feet off the ground.
