running bad
Discussion in 'The Garage' started by gmcjimmy90, Jul 25, 2005.
  1. gmcjimmy90
    gmcjimmy90 Registered Member
    Jul 3, 2005
    76
    arkansas
    i have a 1990 gmc jimmy(fullsize) with a 350 700r and this morning when i was coming home from work it started missing got home and checked everything out all plugs are firing fuel filter recently changed, and no vaccum leaks that i could find. It sounds like a carb. loading up,but it is tbi. have checked and it doesnt look like it is dumping to much fuel.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    How did you check your plugs? Just because a plug is firing when it's out of the engine doesn't mean it'll fire under cylinder pressure. Unless they're new I'd try a new set unless the misfire feels like more than one plug (it would be strange for several to go at once).
    Have you checked for trouble codes?
