Running BB's in the tires?
Discussion in 'The Garage' started by MUD JUNKIE, Dec 20, 2002.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    Running BB\'s in the tires?
    I've heard you can run BB's in the tires for balancing them,does this work? they would make alot of noise would'nt they? clear this up for me,cause 38"s are hard to balance /forums/images/graemlins/thumb.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: Running BB\'s in the tires?
    <font color="green"> If you do a search you'll find some recent discussion on this. Consensus is that it usually works pretty darn well, but for some it has not taken all of the vibration away. For 38s you probably want about 8-10 ounces. They make a little noise when coming to a stop, the noise was described as one shake of a set of maracas. /forums/images/graemlins/rotfl.gif </font color>
  3. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    You could rape some nasty mouse balls... /forums/images/graemlins/grin.gif
  5. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    I run 8 oz's in my 35 inch swampers...no one in town could balance them . They do make an odd noise when you stop but they balance the tires fine to 65 mph. Shakes a quite a bit after 65 so I dont go there:) The tires are awesome so its worth it to me to have them jingle a little lol
  6. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    so how do you do it?
    do you throw the tire on the balancer
    find out how much its off
    break down the tire
    weigh the bb's
    put them in the tire
    mount the tire on the rim
    put back on balancer to find out the results
    is this how you would go about doing it? or can you put them through the valve stem?? /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  7. dammit32
    Jul 20, 2002
    365
    Maine
    I just put the bb's in with one of the beads off ...remounted it with the bb's inside....filled it with air and drove it.
    the balancer couldnt help you the first time around...what makes you think it will after the bb's are in?
    its not like you could move the bb's around if it wasnt just right lol
  8. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    I think I remember some tire balancing goo for motorcycles that looked kinda like a can of fix-a-flat... Hmmm... why not use water?
  9. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    that goo is slime...and it isnt for balancing, its to seal the tires in case if u get a flat. that stuff works awesome. i used to use it when i raced dirt bikes
    NITRO
  10. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    so how much BB's do you put in? is there a set amount?? and you would use the balancer the first time right? I see what your talking about by rebalancing the tire after you put them in. /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  11. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
    No, you don't use a balancer first. If you could use a balancer, then you would balance the tire with the clamp-on weights like normal size tires. The only reason for using BB's is the tire is too big for a balancer, so you don't know where or how much weight to add.
  12. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Balancing 38s /forums/images/graemlins/rotfl.gif
  13. florida4x4
    Sep 9, 2002
    255
    Florida
    not the same as i 'member. this stuff was different - for actually balancing the tire. anyway i guess the way the bb thing works is that they spread out around the inner circumfrence and that way balance out the tire. seems to me that water would do the same thing and be more quiet when you stop. the trick with anything is getting the right amount so you dont set the tire BACK out of balance at a certain speed.
  14. chevyfumes
    Feb 24, 2000
    38,584
    266
    Not sure but I think water may actually heat up and bleed through the tire itself????
  15. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Golf balls work too/forums/images/graemlins/grin.gif
    Iv got 6 per tire and it works great /forums/images/graemlins/thumb.gif
  16. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Golf balls work too
    Even at your normal highway speeds? If they work at 80mph, I'd be willing to sacrifice a few balls for the tires. /forums/images/graemlins/grin.gif
  17. BiggerRigger
    BiggerRigger Registered Member
    Nov 3, 2002
    81
    C.D.A. Idaho
    My grandfather has used (still uses) an old mustard bottle filled with half&amp;half (coffee creamer) as a stop leak and internal tire ballancer the only catch to this is that when you change a tire the cheese that is left over can smell really bad but it will hose right out and will not harm the tire or rim. To use you just take the valve stem out and air down. Place the mustard bottle with half&amp;half onto the valve stem and fill the tire with one bottle of said dairy product. Replace valve stem and air back up. I have used this 3 years ago on my garden tractor tire with a hole that you could fit a #2 pencil through and till this day it still holds air and I have never had to add any air since I put this in. You will never have a leak again, your tires will ballance every time and if you get hungery on the trail and you brought crackers your set.
    Aaron
  18. chevyfumes
    Feb 24, 2000
    38,584
    266
    OK, I've heard it all now, maybe they should start selling cottage cheese with swampers..... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  19. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    golf balls? thats a lot of weight
    I still dont understand.how do you know how much weight to put in your tires?? I was beat with the stupid stick for my vacation this year /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/eek.gif
  20. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    ohh,one more thing,could you squeeze the BB's thru the valve stem?? cause if you can I'll do that tonight! /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
