running bedless??
Discussion in 'The Garage' started by casper, Mar 6, 2004.
  1. casper
    casper Registered Member
    Jan 23, 2004
    15
    Abilene, TX
    Got a long bed chevy, going to pull the bed off to put on another p/u I'm trying to sell. When you run without a bed I assume you lose some traction, how do or can you solve that problem? Also was wondering how hard it is to shorten the frame?
  2. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Do you want to cut off the over hang or move the rear axle forward? Or do you want to move the rear axle forward? If you want the second, this is what i did:
    Spring hanger rivets removed and relocated forward 23 13/16"
    MAssive overhang soon to be cut off
    closer shot of overhang and bracket location.
  3. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    After overhang was cut off.
  4. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Bedless isn't too bad, I drove mine like that for a long time
    You brake a little wierd and you can light up your tires real easy but beyond that it's no big deal
    Make sure you hook up some brake lights though
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you can bolt a pallet down and then some wights on it to help with traction. keep in mind you will most likelye be required to run mud flaps. brake lights. a support rod for your fuel tank.
    go easy on the skinny pedal and all will be fine.
    Grant
  6. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    what are you doing for fuel tanks? I want to do this but i want to keep the twin saddle tanks.
  7. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Casper probably won't see this (not online much) so I'll take the liberty of answering... /forums/images/graemlins/whistling.gif
    He got a tank from a chevy frame (not sure what model) that was about the same as a K5 tank and we stuck it between the rails up close to the cab.
