Running Board removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bking, Jan 15, 2001.
  1. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    I just bought an 85 K5 Silverado. It has I think, original checkered plate running boards fitted. I want to remove them but have a few questions..Maybe someone who has taken them off before can help me out.
    How easy are they to remove?
    What was the condition of the paint below? My paint on the whole truck is in excellent condition, I don't really want to have to spray along the bottoms of the doors etc if removing the running boards leaves the paint behind them in bad condition.
    Any help/tips or advice would be gratefully appreciated...
    Thanks guys.
  2. dyeager535
    26,979
    Running boards on the "tub" that I bought weren't anywhere near the sheetmetal really. Were tehy got close to the body was underneath the rockers. To remove, it was a big pain in the a$$. Bolted in the wheelwells, not a big deal. Bolted all the way down the rocker, to the sheetmetal joint at the very bottom. Again not a big deal, but damn thats a lot of holes for rust to form. The worst was that they welded the supports to the damn body under the cab. And they did it on a surface that you can't get to with a grinder. Ended up using an air cutoff tool, and left the welded on sections in place. Other than those four welded supports, it was easy. I hate those things.
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  3. CK5
    May 19, 1999
    21,623
    701
    CO
    When I bought my Blazer it had running boards on them, just unbolt them and throw them in the trash, you will have some bolt holes in the rocker panel seem, I put the bolts back in to fill up the holes, the paint was fine.
    Steve
    1990 K5 with stuff
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    they should be fairly easy to take of not always but usualy lol paint should be ok maybe a little dirty but should wash and buff out ok
    s.smith 77blazer lookin 4 mud
  5. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    The trail pretty much took off our yukon ones. But there were maybe 4 or 5 bolts in the back . . . not to hard to take off but it isnt the same as a k5 so good luck.
  6. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    spray the bolts with penetrating oil before you touch them. i broke almost all the bolts taking mine off. the reason i took mine off is because on my first 4-wheel trip i bent them and they bent into the body and i couldnt open my door i had to climb out the window.
  7. BigJim85
    BigJim85 1/2 ton status
    Sep 7, 2000
    113
    Lakewood, Colorado
    The paint along the bottom of my '85 Jimmy looks pretty ugly were my running boards used to be, but it's still paint and there isn't any rust so I don't mind. The dirt usually covers the bottom up anyway. Yeah, careful of them bolts too, they like to break.
    <font color=red>If it's stupid but works, it isn't stupid.</font color=red>
  8. Wallyb
    Wallyb Registered Member
    Jan 15, 2001
    24
    Southwest Minnesota
    just wondering why you are taking them off and what are you going to do with them?
  9. OhioJimmy
    OhioJimmy Registered Member
    Jun 21, 2000
    92
    just moved to Kansas, Hoisington
    The other guys explained how to take them off but I'm going to suggest what to do with them when you get them off. They make great shelves in the garage long straight and will hold up well with whatever you put on them. Mine store quarts of oil and other stuff, looks pretty trick for polished aluminum shelves.
    tree? what tree?
  10. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Good idea, I've had some behind my shed for about a year.
  11. BigJim85
    Sep 7, 2000
    113
    Lakewood, Colorado
    They look like CRAP! Made my truck look like a pansy ass soccer-mom-SUV, and I didn't feel like having them get torn off by rocks either. I took them suckers off, kicked 'em around cause they were a pain in the ass to remove, and threw them behind my shed till I can find a better use for 'em. I like the shelf idea, might try it.
  12. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    When you make shelves out of them leave the mud flaps on there...bookends...
    SK-15
    J**P...it's whats for dinner!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
    Roads? Where we're going, we don't need any roads!
