Running Engine Temp
Discussion in 'The Garage' started by mtnman210, Mar 16, 2004.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I was just curious what everyone's engine temp was on street and highway. I've got a 6in lift and 35's on my K5 and my smallblock 350 runs at 190 on street and 205-210 on highway and that seemed high to me. how about eveyone else
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have a 350 with 195 stat. I usually run a little below the 210 mark on my temp gauge all the time.
    Harley
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I think if it's running that high on the highway, you may have some restriction in the radiator, mine runs right at the thermostat (195 or right close) when running around town, and tends to heat up to 220-230 when on the highway especially during summer months here in Arizona. But i already know i need to replace my radiator as it has been pretty rusty and i haven't been able to get it flushed out even after repeated attempts. If your having problems and know your rad is good, try changing that t-stat.
    I'm assuming you are running a 185 t-stat? is it carb'd?
    I am using and actually can only run a 195 in mine, TBI setup.
    I guess if it doesn't continue to climb any higher than the 210 mark you should be ok, but be careful if the outside temps start to rise.
    BTW, make sure you are running the proper mixture of coolant to water ratio, Antifreeze is not a heat exchanger, it only makes the boiling poing of water higher, the water is what takes and transfers to the rad.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my truck runs just under the 210 mark, even with the plow on
    my friends truck runs about 160 with a 195 stat /forums/images/graemlins/yikes.gif. hes got a 4 core rad /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mine runs 195* all the time. Rain or shine, -10 or +100, mine runs 195*. Highway, crawling, trail, you name it, same temp.
    I have a brand new this year three core and a four speed transmission so it isn't pouring heat into my radiator. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  6. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I am running a 350 with a 4 core radiator and a 195 stat, I never see 200, my temp stays at 195 all the time rather in town, sitting still or on the highway. I am also running an oil cooler, tranny cooler and an aftermarket gauge so I know it is correct.
  7. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    thanks for the all the input
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mine runs near 185 - 195 all the time. If its over 100 degrees and my a/c is on it might hit 200 once in awhile. Doesn't matter if I'm street or highway. I have a/c condenser and trans cooler as well as lights and grilleguard all in front of radiator. I am running the stock tow package 3 row radiator with one gallon of prestone and the rest water, a 185 degree thermostat,factory fan blade, and hayden thermostatically controlled clutch. /forums/images/graemlins/thumb.gif
  9. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    a side question on the subject. On a stock gauge with no numbers, what does the halfway mark mean in temp? /forums/images/graemlins/thinking.gif
  10. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    half way--that means you're alright. lol actually i don't know what the exact temp is on that but half maybe a little warm but should be alright.
  11. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    My 350 TBI burb runs at 215 most all the time,IF, I wait for it to warm up for awhile. If I get in and go she runs all the way up to 250-260 for about 30seconds to 1 minute. Then she drops to 215 and stays there. All winter and all summer. I can't figure it out. I have replaced everything except the radiator. I even had the rad pressure checked with some special dye in it to see if I was getting a little blow by from a head gasket. No luck there either. /forums/images/graemlins/dunno.gif
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well if it goes 100 210 240 260 (on my 83) split each one in half and you can visualize the other numbers. And 210 is the halfway mark /forums/images/graemlins/waytogo.gif
  13. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    185 during the winter months and 200 when it's warm outside with my 406 and new 3 core radiator. I am having problems with detonation when the temp rises above about 200 or so and I bought a new 4 core radiator the other day and need to install it. If I run my A/C it will jump about 10-15 degrees warmer. If I start pulling hard it will shoot way up fast too. Also my fan shroud is al hacked up from the body lift and I might wind up running dual perma-cool 2,950 cfm fans .I am hoping it will stay at 185 all day long once the 4 core is in.
  14. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Mine is 210 strait up and down on my guage.I have three lines that read 100, 210, 260
  15. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    cool, i am at right before the half all the time. /forums/images/graemlins/woot.gif
  16. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] That is a little warm in my opinion but is probably OK. I have to keep mine very cool or it will start pinging like a sum of a b!tch...damn siemease cylinders. /forums/images/graemlins/tongue.gif
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Are you carbed or injected? I assume the pinging is at light throttle cruise. If you run vacuum advance , you could get an adjustable one ( allen key through vacuum nipple ) and back it off a bit. Just a thought /forums/images/graemlins/thumb.gif
  18. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Carbed, and it will ping under heavier throttle.
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Ok, I see now. That sucks. Does it matter what you set the base timing at? /forums/images/graemlins/k5.gif
  20. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I have 180* thermostat with a 4 core radiator and 16" electric fan. In town or on the highway, my temps sits right at 185-190*. It will get a bit higher if I am playing the mud. /forums/images/graemlins/waytogo.gif
