Running Hot, Gauge, Wire, Sending Unit??? Which is it?
Discussion in 'The Garage' started by PsRumors, Dec 18, 2006.
  1. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    Here is what I have '85 K20 Burb with a newly transplanted 454, got it running today.
    Temp Gauge is showing at the line between 210 & 260. Replaced the sending unit and got the same thing. The gauge does rise and fall but is just high.
    If my notes I have are correct the following ohm values correspond to the temp.
    210* - 185 ohms
    160* - 450
    100* - 1800
    I put the ohm meter on the sending unit and am reading between 220 and 240 ohms. I am running a 180* thermostat.
    Anyone with experience?
    I want to use the stock gauges cuz that is what I like. It was working prior to the engine change.
    Thoughts?
  2. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Umm I don't know maybe the motor is running hot... It's the only thing you changed right? :rolleyes: Just something to look into.
  3. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    Yup....a possibility but I dont think it is. If you look at the ohms I pulled off the sensor it doesn't appear too. Do you have any experience with the ohms value of the sending unit? I am wondering if my values are correct.
    It doesn't seem the engine is running hot. The coolant temp in the radiator about 10" below the filler neck is at 170*.
  4. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    nope no experience with the ohms... What motor came stock in the burb? Is the sending unit the same as the one that came with the stock burb?
  5. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    It was a 350. I haven't checked to see if the sending units were the same....good catch.
  6. dyeager535
    26,982
    191
    I believe the reistance should be 0-90 ohms, (full sweep of gauge) make sure you've got good contacts, and good wires on your tester.
  7. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    its all in the "ohmage" make sure the sending unit is designed for that kind of gauge
  8. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    one thought..
    Did ya swap in a big block radiator to go with the 454??...a small block one may not be big enough,and will make it run hot!...:crazy:
  9. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    I did swap in a new radiator but all of them have the same part #.
    I do believe though it is the sending unit. Just haven't had a chance to work on it.
  10. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Two ideas;
    Ground the sending unit wire, with the gauges on. The gauge should read full sweep right, at least every one I've ever tried has.
    Are you sure you got ALL the air bubbles out of the cooling system? A large air bubble will do all kinds of weird things.:doah:
  11. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    Grounded it sweeps full hot.
    I believe I have a sensor issue. I just haven't had any more time to work on it.
