running hot(ter)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Feb 1, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I've noticed my engine is running hotter than usual. Not really sure what thermostat I have in there, may be a 160 or 180. During the summer it stayed in about that range. Now it gets a lot closer to 200-210 in the same conditions. I am running 10w 30 in it now instead of the usual 10w 40, and running with the heater on since its cold...not too sure how this effects it. The coolant looks to be in good shape, but a little corrosion i nthe radiator...
    90K5
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    If I flush the radiator will it get the corrosion out or will I need to use something else?
    90K5
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I was running a160 tstat and I finally switched it out to 195. The truck runs alittle hotter but it never gets over 210. I used to worry, but my friends blazer runs at 240 constantly. He doesnt worry so I dont either.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My Jimmy's engine always runs 190-200 in the winter, and 200-220 in the summer. (AZ) You can flush your radiator, and if you use some of the Prestone Flush/ corrosion remover you will get some of the corrosion out. But last time I used the flush stuff in my rad. it turns out that some of the corrosion was keeping my rad. from leaking. So when I started running my truck after the flush, it started leaking, so I had to get a new rad. Also if your engine block is caked in grime, and grease that could contribute to your heat problem.
    Bottom line is the radiator flush stuff works, but in my case it worked too good.
    P.S. You are supposed to change your coolant every year, so if it has been a year, then change it.
    My Chevy isn't broken, its just out of gas.
  5. dyeager535
    26,975
    FWIW, I spent about 2 days cleaning a radiator out on my own (vinegar/water) and when I reinstalled it, same problem. Took TONS of the "scale" out that I could se, but when the engine overheated once again, I pulled it and had it flow tested. It was flowing about 50% of what it should have been. Had the thing (not my truck radiator) recored, problem solved.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    My radiator is only 3 years old, and the corossion is just starting. Last changed the antifreeze Sept of '00, and only drained the radiator. This may sound stupid, but Coke would eat through the corrosion too....could I?
    90K5
  7. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    Check the thermostat... After awhile they can stick or not open completly... the last thermostat that I changed went bad after a couple of months(faulty unit).
    1980 chevy 4x4 1-ton crewcab, 500 caddy, York OBA...work in progress.
  8. dyeager535
    26,975
    3 years is a relatively short time to have radiator problems.
    Mine that wasn't working correctly, looked ok up top, but down low must have been where the problem was.
    Coke might work, never tried it, nor heard of anyone trying it. Then again, if you don't get it all out, it might not react well with the antifreeze.
    Not that everyone does, but did you use distilled water when you changed fluid last? : )
    Dorian
