Running hot with plow on
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigd652, Jan 23, 2004.
  1. bigd652
    bigd652 Registered Member
    Jan 22, 2004
    26
    Michigan
    This truck is used as a light plow truck for the moment. When I have the plow on she runs hot like 240ish hot. Any ideas on how to keep her alittle cooler?
  2. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    Re: Runnign hot with plow on
    try keeping the plow lower in transit to allow more airflow into the radiator
    yikes 240 is hot...is the cooling system up to par?
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    on my truck if i run it with the plow all the way up it will run just as hot as yours. i have a western unimount and i run it just high enough that i can just see the lift arm but no chain. and it runs about 210 or less. you could also try turning it a little to the side to allow air to come in from the side /forums/images/graemlins/thumb.gif
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    If it has a clutch fan on it, take it off, run a 2" spacer and a good fan with at least 6 blades. and make sure the fan shroud fits right.
  5. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I have an '87 Chevy with a 454 as a plow truck. I just angle it all the way to the right and drop it as low as I can on the highway or anywhere I go over 35mph. It stays nice and cool usually... right under 200 even when going 55.
    Theres also an electric fan on the truck that was on it when I got it. It used to work when it got a little hot, but it hasn't kicked on this season.
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    all good advice so far. make sue you are not running rich. pushing a plow requires a bit more right foot, so you could be getting to much fuel.
    especialy when its cold out.
    Grant
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Richer mixture would make it run colder not hotter, and having more right foot doesn't make the mixture richer anyway. When you add air, the carb adds fuel.
    I think you should flush your radiator and be sure your fan is up to par. If that doesn't help, add an electric fan to the system but leave the fan that is on there.
    I run a 7 blade fan on mine and I never have cooling issues. I can imagine that the plow really scucks at blocking airflow though.
  8. bigd652
    Jan 22, 2004
    26
    Michigan
    I have a Boss... Not sure on size but I do think its to big for this truck.... I ran her today with the blow darn near all the way up and she ran around 220ish. Gonna flush the cooling system and see if that helps at all. Is it really bad to run her that hot?
  9. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Its not a good idea to run it that hot. First really hot day of the summer last year I drove my 95 k2500 home all on the interstate with the plow on. I had to drop it so low that going over overpasses it scraped, was a cosntant battle to keep it cool.
  10. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    My 87 blazer came with a clutch fan with 3 blades. Didn't work at all hit 240 in less than 3 miles after I put the plow on. dumped the clutch fan and a 2" spacer, never hit 200 agian. How many blades are on the fan you have?
  11. bigd652
    Jan 22, 2004
    26
    Michigan
    Not to sure but I believe 3..... How do I replace it and where do I get a new fan?
  12. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I got mine a advanced auto. The spacer, which comes with new bolts, was 12.00 The new fan I got was 29.95. Your upper fan shroud comes off, so that will make it easy. there are 4 bolts 1/2 way down the side of the shroud. 2 on eather side. And the shroud bolts to the top of rad suppoet. There are 4 nuts that hold the fan and hub to waterpump pully. remove the nuts and pull fan and hub off. You will have to remove the studs that are in the pump. Once they are out, place spacer on and fan. use the new bolts and your home free. I don't usually remove the belts. The tension from the belts will hold the pully in place.
  13. bigd652
    Jan 22, 2004
    26
    Michigan
    Well I can get down to 210 solid running 55. Just have to put the plow pretty high but it works better.... /forums/images/graemlins/wink.gif
