running like [I love Jeeps]..now no brake pedal
Discussion in 'The Garage' started by bryguy00b, Sep 11, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok my truck has had a loss of power..stumbles..surgis..ect..and now i have hardly a brake pedel..goes wayyy down to the floor just about. but i didnt see any leaks on the lines or any damp spots..and the fluid level is fine..related..?something with the booster?
  2. wild-will
    wild-will 1/2 ton status
    Aug 21, 2003
    185
    Oak town WA
    bleed your lines buddy
  3. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Id be willin to bet that somethin is up with your vacuum system. Check that.
  4. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I second that I have had vacuum problems before and those are some of the signs....Jason
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok uhh buddy thats doubtfully the problem though..speacialy considering they started working fine after that..it just went back to normal! so im guessing some kind of a vacum issue..
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    how exactly do i check it?
  7. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    get a vac gage and T into the booster line. At idle it should read about 20pounds. Other than that i might sugest bleeding brakes becouse you might just have an air bubble, is that out of the question? /forums/images/graemlins/thinking.gif
